Originally Posted by
jschrauwen
Excellent excellent. Thank you. Nice to hear it's not too overly complicated. I've got the part number for the manifold gasket kit but I'm thinking there should be two throttle body gaskets and not one?
https://www.ecstuning.com/b-assemble...t/079198074kt/
Service records from Pfaff Tuning show the injectors were replaced. I'd have to confirm when. IIRC, it was 3 or 4 years ago.
Since the manifold will be off, I figured I should probably replace the the PCV / Oil Separator? Did you replace yours during your carbon cleaning?
You wouldn't happen to have a yellow RS4 would you?
That kit that you linked looks like it's for the RS4 and not the R8. The manifolds are different as you know. I don't have much info on the R8 throttle bodies, but the picture in the link looks like the throttle body gasket for the RS4, I'm not sure if they're the same for the R8 or not.
PCV replacement is never a bad idea, at the same time you don't want to throw away money. If you're noticing excessive oil consumption it could point to the oil separator, if you aren't seeing issues with it, your call as to if you want to swap it or not.
I don't have a yellow car, but I know of a couple yellow RS4's around Toronto. One of the guys started an RS4 whatsapp group for Canadian RS4 owners. His car is quite nice. He has a carbon fetish and has alot of really nice pieces.
