Results 1 to 6 of 6
    Senior Member Two Rings zephyr125's Avatar
    Oct 06 2008
    98.5 B5 2.8, 74 BMW 2002, 82 BMW R65LS
    Corte Madera, CA
    Heater Core bypass/pipe leading to HC replacement
    So I went to flush my heater core the other day when I removed one of the hoses from the pipes that leads to the heater core to discover that the pipe had degraded over time. After I flushed it I hoped to clamp it high enough up the pipe that it wouldn't leak but that didn't work. How would you guys go about bypassing it/plugging it until I can replace the pipe. Also do you know what part that is called?
    Here's a basic pic from the internet with some of my MS paint skills to show where it has broken:
    I'll take an actual picture in the morning, sorry about the crap one for now.
    Senior Member Two Rings robertbutnar's Avatar
    Apr 01 2009
    e32 735i, 16' apollo boat
    bellevue wa
    take out both pipes and connect them to each other you will have no heat
    Oct 06 2008
    Corte Madera, CA
    What would you use to connect the two?
    I'll probably just run down to my hardware store in the morning and figure it out but I figured I should see what everyone thinks before I go do that and spend money. Sorry for seeming like a noob.
    Sep 18 2009
    Montreal
    Thankkkkkksss a lot !!! i was searching where are the hoses that goes into the car to the heater core.
    Now i can flush it yeah !!
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    get a peice of pipe to connect the hoses to each other and be done
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Connect the two hoses you removed from those two pipes together, that will bypass the heater core. You will have no heat, but you will not leak/overheat.
    Those metal pipes are your heater core. Replace that and you are good to go.
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
