    Active Member Two Rings Drinnen's Avatar
    Jan 26 2009
    Sac
    Exclamation Cluster Issue! PLZ HELP!
    Soo I took my car into a audio shop and had my subwoofers hooked up to the stock deck using a high-low converter.
    After everything was hooked up the top third of my cluster stopped working but not completely...
    Top portion works fine when the car is not running but when it is its just black!
    I had them disconnect the converter and its still doing this!!
    Any ideas of what the issue is??
    // 01 Silver S4 6 speed // Apr Tuned // Stage 2 // Milltek 3" Cat-back //
    Senior Member Three Rings Audiophyle's Avatar
    Jun 24 2009
    ABQ NM
    Go to a better audio shop maybe?
    I would guess they either tagged something they shouldnt have, or forgot to plug something it.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Quote Originally Posted by Audiophyle View Post
    +1
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Feb 07 2008
    The boonies, near Seattle
    There shouldn't have been any reason for them to even be near the cluster though.
    OP, find out where they got signal and remote turn on.
    -dre
    Jan 26 2009
    Sac
    Well i know they didnt go anywhere near the cluster but im guessing it has something to do when they were wireing the converter to the deck. No idea what it could be though... Goin to pull my deck after i get some tools to remove it and hopefully ill visually be able to see something!! Thanks guys
