Results 1 to 8 of 8
    Apr 27 2010
    OR
    Exclamation 01 1.8T Making ticking sound
    http://www.youtube.com/watch?v=svERT...eature=related
    Today my engine check light turned on and it's been making that sound ever since, I went in and got it checked out it said it had something to do with my intake or camshaft sensor or something. I tried looking it up but couldn't find anything that helps, does anybody know what's wrong?
    Jun 10 2010
    is the oil level fine?
    Apr 27 2010
    OR
    You think the check engine light would go off if the levels were to low?
    Apr 07 2010
    Indianapolis,IN
    I had a bad ticking sound upon start up, I got on the highway and my oil light started to flash, I checked oil, it was low. I added oil, this didnt help. I changed oil and filter and sounds and runs normal and the light has gone off including my CEL. This just happened yesterday. So yeah this is where Id start.
    99.5 A4 1.8 T Laser
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by Clewe View Post
    the check engine light isnt going to be related to a low oil situation, the low oil situation is connected to the oil light on the dash, most likely your low on oil or its needs to be replaced, better do an engine flush before you burn up the top end of your motor, sludge is an enemy get rid of it asap
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Apr 27 2010
    OR
    Quote Originally Posted by 99blueb5 View Post
    Thanks a lot, is there anywhere I could find out how to do an engine flush on my car? I don't really want to take it in for something like this.
    Jun 10 2010
    my oil light would flash occasionally a while back.
    i put seafoam into the crankcase and then changed the oil with Mobil 1 0-40.
    light hasnt came back since.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    just search on the forum im sure someone did a write up on it, very easy to do but if done the wrong way then it can cause lots of damage
    99 A4 1.8TQM:
    00 B5 S4
