Results 1 to 9 of 9
    Established Member Two Rings chrisaudi4.2's Avatar
    Jan 26 2010
    paterson nj 07514
    convenience module,where is located on a 2000 a6 4.2
    cant someone tell me where is the convenience module,located.please thanks
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    you will find this bad boy under the carpet on the drivers side.
    Veteran Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ TDI Roadster 6MT, 2001 A6 4.2 6MT, 2005 Jetta Wagon TDI 5MT, 2006 CBR1000RR
    Plano, TX
    gotta pull lower dash, kick panel. dead pedal, door sill, seatbelt, and seat. Why do you need to get to it? Do you still want to?
    Jan 26 2010
    paterson nj 07514
    reason I ask is cause I been having problem with all 4 windows.they keep coming Down without tuching the remote,some people told me it could b wet,but I took it apart and no the drivers side and pasenger side r completly dry.so Do u guys think may b the convenience module go bad...
    Apr 22 2010
    Plano, TX
    I've been dealing with some water ingress issues lately that lead me to believe your module might not be the problem. My floor has been underwater so long that a penny that was under the CCM had turned green, and everything still works fine.
    Is there any other weird behavior? I thought remote until i saw without touching it. Sounds silly, but maybe a short in your remote or your driver door key cylinder or associated wiring is the problem, since it can cause the same behavior. Get into measuring blocks and see if there's a button pressed that shouldn't be. I'd suspect that before I'd suspect a module.
    Jan 26 2010
    paterson nj 07514
    well may b I should take the door panel off.cause bfore I could bring the windows Down by putting the key on the Drivers door cylinder....but now all it does is they go up but wont come Down and also the power looks keep going up an Down.and the back pasenger winDow only go's up halfway........
    Apr 22 2010
    Plano, TX
    Stop taking things apart and figure out what the module sees before you do anything else.
    Jan 26 2010
    paterson nj 07514
    finally got the car fix,the problem was the Drivers door lacth I replaced it. now eberything is back to normal.also thanks eberyone for the help.
    Veteran Member Three Rings ccomengee86's Avatar
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    nice engRish
    </sarcasm>
