Results 1 to 23 of 23
    Veteran Member Three Rings pismojeff's Avatar
    Apr 10 2004
    Bend, OR
    gutting cats on s6?
    anyone done this? I am getting a CEL from a bad cat that comes up every once in a while and thinking about having my shop just gut them... need to know if anyone has done this on the S6 and if they have a kit to get around the CEL that results from this. I know they make them for your 2.7's but was not sure about the S6
    thanks
    2017 Audi Q7 3.0T
    2000 Porsche 911 Carrera
    RIP: 02 S6 - H&R springs, 19 BBS LM reps, RS6 front my ride
    Veteran Member Three Rings ChescoS6's Avatar
    Jan 13 2007
    2012 Golf TDI 2003 Ducati ST4s ABS 2007 Ducati Monster S2R
    PA
    Or you could just cut them out and replace with a pipe fitted with a bung for O2 sensor and anti fouler. I don't see a problem with gutting them though. I plan on having mine removed when I do my exhaust.
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    just use O2 sensor spacers made from spark plug non foulers. No need for a "kit"
    BUT if the actual O2 sensor is bad, then this isnt going to fix your CEL. That happened to me when I gutted teh downpipes on my 2.7t that had O2 sensor codes...but hey, now I have gutted downpipes which I had wanted to do anyways!
    Chesco--I imagine he means the pre-cats are bad.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Apr 10 2004
    Bend, OR
    yeah, I don't think I will do full exhaust unless I keep the car a while. just trying to get around the CEL and add a little sound/performance
    2017 Audi Q7 3.0T
    Apr 10 2004
    Bend, OR
    yeah the CEL is from a bad cat, not a bad sensor... I will see if my shop knows this method you are speaking of. still hope to hear if anyone with an S6 has done this
    2017 Audi Q7 3.0T
    Apr 10 2004
    Bend, OR
    ok, this is what I got back from my shop. let me know what you think:
    "Removal & replacement time for your catatlytic converters (Standard Labor Time) 3.5 Hours/ $315.00
    We have a few options for replacement - We can either:
    1 - Save your exsisting cats & have Shane @ Custom Exhaust Specialties, fabricate NEW Cat-by-pass tubes w/ the j-pipes for the 2nd O2 Sensors. - Addition fabrication time from Shane.
    2 - Gut out your existing Cats - Cut them open & remove the catalysts material & re-weld the units. Then attach the j-pipes for 2nd o2 sensors and re-install. - Additional time for cutting cats open, hollowing them out, re-welding units & install j-pipes for replacement is expected to take between 1.5&2 hours to do both Banks. = $135-$180
    What do you think?
    Expect total cat-bypass to be around $450-$550- w/ J-pipes purchased & Installed by us."
    2017 Audi Q7 3.0T
    Sep 18 2006
    Colorado
    3.5 hours to pull and reinstall? Lol. Something tells me they've never removed the down pipes from and audi v6/v8. I understand they are professionals, but it's a bitch of a job, even with a lift and all necessary tools.
    I'd go with whatever option is cheapest, either version of what they are saying sounds good.
    Apr 10 2004
    Bend, OR
    so you think his time estimate is a little low? sounds good to me...
    2017 Audi Q7 3.0T
    Sep 18 2006
    Colorado
    If they will do it for that price go for it, but it took me and a friend 10 hours total to gut mine, and he had done a few other cars before mine.
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    The downpipes on the S6 are easy to remove. I've done it with the car jacked up in my driveway.
    They actually do not need to remove the downpipes because the cats can be sawn off while still on the car.
    With them out, they can either be re-welded and re-installed (to pass visual I suppose) or straight pipes can be spliced in.
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
    Apr 10 2004
    Bend, OR
    thanks steve... glad to hear from someone with experience on this. so sounds like it might even be cheaper if my shop goes this route. did you do this on your S6?
    2017 Audi Q7 3.0T
    Jan 11 2005
    Pittsburgh, PA
    No. My cats seem to be good. What's the mileage on your S6? You know there's a recall/warranty that good on the S6's up to 100k miles/ 10yrs. The dealer will replace them for free if you're under this mileage. (search qw for details on this)
    FYI, the S6s do not have pre-cats either (one reason why they're easier to remove). So don't let anyone sell you on gutting your precats or special modded code for gutted precats, etc. since you've already got them.
    EDIT: here's the link: http://forums.quattroworld.com/a8/msgs/14131.phtml
    Steve
    Apr 10 2004
    Bend, OR
    yeah, actually just about to hit 104K miles... my shop told me about that warranty but looks like I am out of luck
    cool, I know my shop is super honest but that is good to know anyways on the pre-cats. I will see what they think about doing the job without removing the downpipes
    2017 Audi Q7 3.0T
    Jan 11 2005
    Pittsburgh, PA
    You might be best off just taking it to a muffler shop if you can find one that will do it irregardless of the legality.
    Steve
    Apr 10 2004
    Bend, OR
    I am in Bend, OR so I am pretty sure legality is not an issue... I could be wrong though
    2017 Audi Q7 3.0T
    Feb 07 2008
    The boonies, near Seattle
    My vote is option 1, but you will need defoulers.
    The secondary o2 sensors are basically there just to make sure your cats are still working, so they have little pertinence to how your car is running.
    -dre
    Apr 10 2004
    Bend, OR
    so the j-pipe thing is separate from the defoulers?
    2017 Audi Q7 3.0T
    Feb 07 2008
    Quote Originally Posted by pismojeff View Post
    I honestly don't know what that is referring to; we might just be using different terminology.
    -dre
    Apr 10 2004
    Bend, OR
    yeah, I am pretty clueless. this is what I was talking about: http://www.raimotorsport.com/RAI-J-P...p/11620vib.htm
    2017 Audi Q7 3.0T
    Feb 07 2008
    Ah. From that link it looks like a j pipe is just a fancy defouler. Right on.
    -dre
    Apr 10 2004
    Bend, OR
    ah, so where does one get these less fancy defoulers?
    2017 Audi Q7 3.0T
    Jan 13 2007
    PA
    Apr 10 2004
    Bend, OR
    awesome. thanks for that link
    2017 Audi Q7 3.0T
