Results 1 to 20 of 20
    Dec 07 2009
    Denver
    Torn passenger inner CV boot..suggestions pls.
    I recently noticed a slight vibration under acceleration but only when carrying 2 or more passengers, I currently dont feel it its just me in the car. Today I noticed the inner CV boot is torn. Its been may 100-200 miles since I first noticed the vibration (only under acceleration) I'm wondering if I should just replace the boot or the entire axle...Is there a good way to tell if CV has been ruined? I don't want to do the boot only to find I still get a vibration.
    Also any recommendation for replacement boots/axles? raxles.com seems to be the preferred for the axle but curious what other have found.
    Thanks
    Account Terminated Four Rings
    Oct 26 2009
    Beaver Creek, CO
    From what I've read aftermarket axles aren't quite as good as the OEM axles (someone correct me if I'm wrong).
    Though it is easier to replace the entire axle, it is also much more expensive. A boot kit will run you around $20 or so, while an axle will run around $125ish. I replaced my rear outer CV boot last week and it was a greasy mess and a bit of a pain, but more logical than replacing the entire axle.
    May 05 2010
    B6 A4 1.8T
    Los Angeles, CA, 90059
    dammn i had the same problem with my passenger side cv boot..it tore and it all went down hill from there..you should get a new drive axle because when the boot rips all the junk n dirt that pops up from driving gets in there and corrodes the ball bearings in the axle so they become loose and the axle will go bad anyways..it won't work properly..it cost me a little under $200 for a new drive axle..and its something that you could do yourself so you dont have to worry about labor fees.
    B6 A4 1.8T>>boosted tech CAI::Forge splitter::Rebuilt engine head & block::Victor Reinz steel gaskets & head bolts::SS tubular exhaust mani::TT225 injectors::VMR straight pipe::VMR vent boost gauge::custom FMIC::DNA OCT::custom exhaust::tein SS coilovers::B5S4 brake upgrade::drilled/slotted rotors::19" BBS RS GT's::black halos W/4300K Xentecs::6K fogs::limo tint::debadged::blacked out grill::roof spoiler::lid spoiler::Apexi TT&companion
    ...More to come sooon(:
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Also I believe you have to do the outer boot to do the inner boot just for info.
    Veteran Member Three Rings bora_1_8t's Avatar
    Sep 09 2009
    2004 B6 A4 1.8T Q6M, 05 Honda VTX 1300C
    Albuquerque
    If you look online at autoz@&$ or advanc@& a@t$ I found complete half shafts for like $80 with warrantees brand new and I'm
    In the same boat I have to replace my front inner cv boot and I've used these before on my old Ko4 GTi and had no issues so I'm gonna be ordering one here in the next week
    mods: Koni coils, suede door and dash trim, BSR cat back, samco hoses, TT injectors Unitronic Stage 2, water/meth and brushed aluminum trim and badges
    "No bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country." George S. Patton
    Dec 07 2009
    Denver
    Yeah I've read post on the AA replacements, they have had mixed reviews on them. Most posts say try to keep the stock if possible. Just not sure how far gone mine is, if a good cleaning, re-grease and boot would do?
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    raxles.com sell OEM refurbed. that is why they are so good. they dont use anything but what comes out of Germany. I spoke with Marty about this a while back. they have a lifetime warrenty as well. only downfall is they are expensive.
    Dec 07 2009
    Denver
    One other question, my upper control arm bushings are bad, would it make sense to do that at the same time while I'm in there?
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    I had an aftermarket axle go and it took so much other stuff with it, I was out $2500. Broke right at the flange.
    Raxles. Always.
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    raxles.com FTW!
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Oct 26 2009
    Beaver Creek, CO
    Quote Originally Posted by a4huey09 View Post
    I would. It's actually quite easy to get the suspension assembly out, the time consuming/harder part is getting the bushings tightened after you reinstall it. Just remember to load your suspension before tightening the controls arms so you don't tear the bushings, again.
    Senior Member Three Rings tapA4's Avatar
    Aug 25 2010
    2003 A4 1.8T FWD 5 speed
    Greenville, SC
    YES! this thread is a gem! I was just about to post up about mine. My passenger inner boot is torn as well....Haven't noticed any strange noises, but I just noticed that it was torn while under the car a few weeks ago.
    Does anyone have a link to where I/we could buy an inner passenger cv boot kit??
    -Theodore-
    "I swear, your mom and I are just facebook friends."
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    Quote Originally Posted by tapA4 View Post
    I got mine from the dealer. ;)
    Aug 25 2010
    Greenville, SC
    Quote Originally Posted by IVRINGS View Post
    Noooo! lol I don't like the stealership. I dread trips there...like a kid to the dentist haha. Well how much abouts did you pay?
    -Theodore-
    Dec 19 2009
    99 Honda Prelude Type SH, 2004 H2
    Murrieta
    Is there a diy thread for replacing the boots or axels? I have to get this done as well.
    Aug 25 2010
    Greenville, SC
    Quote Originally Posted by frcdfed View Post
    Search it. I would imagine so.
    -Theodore-
    Oct 26 2009
    Beaver Creek, CO
    http://www.audiworld.com/tech/wheel37.shtml
    http://forums.vwvortex.com/showthread.php?3344208
    I wrote one for the rear outer CV boot, but I'm still waiting for it to be approved...
    Dec 03 2008
    Orlando, FL
    Whoa!!?? this just happened to me. did my brakes and noticed my passenger inner CV boot was torn. after some reading about suspension noises here, i also checked my ball joints and they were torn as well. took it to VW dealer and they couldn't unfreeze the tie rods. a few days later my fans quit so i went to the Audi stealer. fans and relays were covered under warranty, but not the tie rods,cv boot, or ball joints. looked over my warranty coverage and found the tie rods and ball joints were covered but not the cv boots. they were trying to say the tie rods and ball joints were corrosion, which i told them so what they are covered, period. they agreed to fix them. cv boots are just wear n tear.
    I did a search on here and found the outer boot is a relatively easy repair but could not find a DIY for the inner boot. thought about just replacing the axle, but the techs at both the VW and Audi dealers said that these axles are solid and some of the best around and if i went to AA or another store i could be getting sub-par equipment. these axles are discussed in depth here and other forums and this seems to be true about how good they are.
    i paid the audi dealer $200 for the cv boot which he came down from $289 to beat the VW dealer's price, $100 deductible and got $2500 worth of work done ($1600-2 fans and relay; $689 for ball joints; $211 tie rods).
    Feb 12 2005
    Denver
    Since our axles are very high quality, recommend having your OEM CV axles rebuilt by your best local axle facility. Recently did this with my front left that was torn/fully leaked for several months. Went to a local shop that works on porsche/audi/bmw and off-road heavy duty. Came back 3hrs later looking new. Should cost you between $70-80. For Denver guys, recommend CVJ Axles or Rocky Mountain Driveline FWIW.
    Sep 09 2009
    Albuquerque
    Well I just ordered mine from autozone it's a re manufactured OEM plus it has a life time warrenty only 70$
