Results 1 to 6 of 6
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Timing belt tensioner question, Engine back together BAT content
    Okay so this has been on my mind since Ive got the car back together. I bought the timing belt kit from 034 but am I missing something? I manually adjusted it so that its tight. The engine is a 06A (AWM block) with a AEB head. When I took the engine apart to do springs, retainers and inconel valves, I redid the timing belt and it had the same components as before. Im getting the car tuned on the dyno soon so I just want to make sure Im ready to go. Thank you.
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Jun 30 2008
    Erie, Pennsylvania
    Ah, that looks the manual tensioner roller from a Jetta 2.0 engine. That is a fully manual tensioner, no hydraulic component necessary. You just have to put it to the proper tension yourself. Also, you may want to check the belt tension every 20-40k miles or so to adjust for belt stretch. The hydraulic units obviously self-adjust for this purpose.
    Oct 15 2007
    Telford Pa
    Walky, thanks for the info. It makes me feel alot better knowing what I have.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    yeah as long as your marks line up your good to go, i would make it a habit to visually/check the belt tension every time you open the hood, you want to make sure that belt stays tensioned all the times or else you will be doing head work again...which is never "fun"
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Registered Member Three Rings seanriv's Avatar
    Jan 07 2008
    2001 Audi Allroad, 2015 Mini Cooper
    San Francisco,CA
    No tensioner! Something doesnt seem right. I might be wrong but I would show 034 or call first before you turn that beauty over.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by seanriv View Post
    if you would read above^^^^ he is running a MANUAL tensioner not a hydralic tensioner.so therefor the manual tensioner is part of the roller assembly
    99 A4 1.8TQM:
    00 B5 S4
