Results 1 to 19 of 19
Thread: Cheap, fun Mod
    Jun 23 2010
    Athens, PA
    Cheap, fun Mod
    I was looking to get a louder turbo and DV sound. Looking at a Forge 007 DV (people say they're quite loud), and a suggestion for air intake upgrades if needed? I have searched, heard either cone or drop-in panel can damage MAF. Can't really find anything that says if the panel is just as loud as a cone filter. So I was wondering how to make it louder in any possible ways and what is the best options from personal experience if any have it. Thanks everyone
    PS- Car is all stock otherwise except for clutch.
    Active Member Two Rings //AudiA4's Avatar
    Aug 11 2010
    RIP APR STAGE 3 A4B6
    Birmingham Michigan
    i have the apr carbon fiber cold air intake, that has a loud diverter valve sound. i have a stock valve blow up and with my cold air intake it sounds sick. can hear it in the cabin clearly...
    Derreck
    Jul 12 2007
    Massachusetts
    Quote Originally Posted by //AudiA4 View Post
    Derreck
    The "APR Carbon" is actually a Carbonio.
    2020 SQ5
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    No need to spend all that money for sound. If you want a loud DV sound go to autozone buy a cone filter and stick it on the end of your maf. You will be surprised how loud the stock DV is.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    WTB Blow up valve
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Jun 23 2010
    Athens, PA
    Quote Originally Posted by lowandslow4now View Post
    I'm also prepping for a BT build so ill need an upgraded DV eventually. Is a panel filter just as loud as a cone filter?
    Oct 03 2008
    what garage?
    Pittsburgh
    Quote Originally Posted by AudiNFS View Post
    No
    16' Silverado HD
    Jun 23 2010
    Athens, PA
    Quote Originally Posted by SantorianA4 View Post
    No
    Do you have a cone filter? If so, how do you like it the noise with everything and have you had any problems with it with your MAF or anything? Thanks
    Jun 30 2008
    Erie, Pennsylvania
    Just get a Forge Splitter valve. They sound cool, but not obnoxious and if you don't like it you can cap it off and make it just a DV again. The best of both worlds. If you have a 2000+, make sure you bypass the N249 as it will cause issues with the atmospheric nature of the valve, but other than that it works great.
    Jun 23 2010
    Athens, PA
    I heard they were more of a hassle to install though? The splitters. I also have a '98. By the way, been driving the new FX300 w/ steel LWFW around. Amazing clutch! everything you said it would be
    Jun 30 2008
    Erie, Pennsylvania
    Nope, they are just fine to install, nothing different at all. That said, I've only seen them installed in the lower DV position. Early 1.8T's had the DV in the TIP instead of the charge pipe. I don't know if the 98 has that or not, or if that would be a problem. The splitter is only very slightly larger in 1 dimension than a normal valve, and it has the horn thingy sticking out the side.
    Not a problem at all on my brother's 2000 1.8T. He loves it. It makes the blow-off noise when he revs it in the parking lot. It is loud enough to enjoy with the windows down and quiet enough to ignore with the windows up. Just right.
    Jun 23 2010
    Athens, PA
    Sounds good. I'll have to ask about it with the '98. Thanks for the info
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    I'm running a K&N cone right on the end of the MAF with a Forge splitter and a test pipe w/ 2.5 SS exhaust, quite loud, sounds phenomenal. I get compliments often
    ^^^This.
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
    Jun 23 2010
    Athens, PA
    Quote Originally Posted by bikerbob951 View Post
    ^^^This.
    is a test pipe different from a downpipe? i'm a newb. also, did you need a u-bend pipe and heat shield with the cone filter? Thank you
    Established Member Two Rings dtmeurosport's Avatar
    May 03 2010
    earth
    is a test pipe different from a downpipe. i'm a newb. also, did you need a u-bend pipe and heat shield with the cone filter? Thank you
    I had to run a u-bend pipe with my cone filter and I reused the stock heatshield with some wire holding it in place. I can't comment on the DV sound because I was running an HKS SSQV blow off - hella loud! haha
    (don't worry, now I have the stock airbox w/ a K&N filter and a Forge 007. growing up FTW!)
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    I have the cone filter, upgraded intake track, upgraded induction hose with up graded turbo with the 007 DV....I wouldn't say it's loud.
    Established Member Two Rings DrkZide's Avatar
    Aug 08 2010
    Denver
    I though you need a DV and not a BOV due to metering issues. Is there a way I can run a BOV on a 2001 A4?
    Absurdum est ut alios regat, qui seipsum regere nescit
    "De Oppresso Liber" - "Nous Defions"
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by DrkZide View Post
    they have kits that allow you to do that, but DONT waste your money, there will be NO benifit, trust me and everyone else, get a foge 007p and that will sound amazing with a open filter, you do not need any more noise than that
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Aug 08 2010
    Denver
    Quote Originally Posted by 99blueb5 View Post
    That was more out of curiosity lol
