Results 1 to 3 of 3
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Buying manifold hardware.. Nordlock washers for use with mani to block also?
    ok so next week i am replacing my pos manifold with a treadstone and want to secure everything so i dont need to tighten it again.. i am going to be using nordlock washers for manifold to turbo was wondering if it would also be good to use nordlock washers for manifold to block if not could someone please direct me what to use..
    http://www.034motorsport.com/hardwar...e-c-40_56.html
    theres a shitload of nuts in here and am not sure which will be best.. any advice will help with what nuts to use for both mani to block and turbo to mani and also if nordlock washers would work well on the block i just really want everything to be set and no loosening
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I would just recommend the copper nuts for the manifold to the head (available at 034).
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 13 2007
    Belmar,NJ
    any washers?
    Past cars:
