Results 1 to 12 of 12
    Sep 30 2010
    MD
    VAG - VCDS - K1 Short to ground
    It appears that there is an electrical short in the engine, and the engine won't start. I get the K1 - Short to ground error when connnecting the VAG - VCDS.
    I tried issolating the module that was "shorted to ground" by disconnecting the connector pos. 5 in the E-Box Plenum Chamber. This allowed me to scan the remaining modules. But I was unable to scan the engine, and the transmission returned:
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4B0 927 156 AK
    Component: AG5 01V 2.8l5V USA 3132
    Coding: 00002
    Shop #: WSC 00000
    VCID: 70E526F91AD1
    2 Faults Found:
    18258 - Powertrain Data Bus: Missing Message from ECU
    P1850 - 35-00 - -
    18262 - Powertrain Data Bus: Hardware Malfunction
    P1854 - 35-10 - - - Intermittent
    Any suggestions on further issolating the short?
    Thanks.
    Gene
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    Do you have an aftermarket stereo, the K line runs to the back of the OE unit
    I don't think I care anymore
    Sep 30 2010
    MD
    No. I do not have an after market radio. The radio functioned when I disconnected the offending connector. I was also able to scan the radio.
    The connector in pos 5 of the E-box plenum, has the moldule that appears to have a short. But I have been unable to issolate beyond that.
    Sep 30 2010
    MD
    Bentley Repair manual leads me to believe I need to find the A-Pillar Left connector station, which will allow me to disconnect individual modules. But the manual is not clear on exactly where it is located.
    Aug 04 2007
    It is behind the kick panel, drivers side, almost directly below the fuse panel. Remove a couple of screws and pop out the plastic, mountains of connectors in there
    Quick search on google turns up results related to immobiliser active
    Sep 30 2010
    MD
    Thanks. I should have included it was a model year 2000. The manual says the immobilisr was not on A6 until 2001, but the dealer lead me to believe I had the immobilizer when they sold me new keys.
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    The VAG VCDS that you used, is this a original Ross Tech cable or Ebay ?
    If you have problem with communicating with ECU, I would not be surprised the K-line trace and ground trace are burned inside ECU module .. possible ECU is damaged, check the ECU box for any wires burned or any burned smell
    I have seen that happened
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Sep 30 2010
    MD
    Yes. I have an original Ross Tech cable. I willl check the ECU. Thanks.
    Sep 30 2010
    MD
    SO. I opened the ECM and found the circuit board is charred. How easy is it to replace the ECM.
    Aug 04 2007
    check the classifieds
    Feb 08 2005
    Ontario, Canada
    Quote Originally Posted by genew View Post
    good work.. now check all ground post for any broken connections or rusted wire that doesn't connect anymore, there should be one near ECM box, and two ground posts inside the car on the driver side footwell on the left side you need to remove the knee bolster and the lower trim to see all your ground
    Sep 30 2010
    MD
    Quick Follow up. I could not find another short. I plugged the used ECM in the car and the car started. At least on the 2000 A6 it does not appear to have an immobilizer and the ecm does not need to be reprogrammed.
