Results 1 to 11 of 11
    Active Member Two Rings new audi guy's Avatar
    Jan 19 2009
    Columbus, Ohio
    strange noise at startup?
    ok, i've got a 2004 A6 s line chipped with APR 74,000 miles now. had it a year now... absolutely love the car.
    since the colder weather blew in every morning at startup and until car warms up there's this strange sound coming from engine or belts... its kind of a low pitched sound that sounds like something's not lubricated...
    it changes in pitch according to acceleration and when i turn steering wheel sometimes....
    any idea what i'm looking for here? should i not be driving it till i get this fixed?
    i do need to do the 75k service timing belts etc, so I will get this fixed as well
    appreciate any thoughts!~
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    power steering pump possibly. if you turm your wheel to full lock left or right does it get considerably louder?
    I've gone to the dark side - F25 X3
    Previous - '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    is it only on startup and turns off suddently once car is warm? If so, secondary air pump. Ignore until it throws a code, could take years. In very basic terms it's a choke.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Jan 19 2009
    Columbus, Ohio
    Its only when the car is cold in the morning... once engine warms up it goes away. I guess it could be two different issues at once. The sound is kind of like if you've ever seen a washing machine get the load spinning lopsided and it starts making a rhythmic lurching sound. and it speeds up a bit when the RPM's increase
    It doesn't seem to get dramatically worse when steering wheel is locked out though....
    I tried to take a short video of it.. but not sure its audible in this clip.
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    Check your steering fluid levels.
    '91 Coupe Quattro - 034, H&R, Autocraft, Keskin - S2 look alike
    '06 A4 Avant 2.0T Quattro Manual
    '12 Touareg TDI Lux
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Quote Originally Posted by new audi guy View Post
    I couldn't hear anything, but if secondary air pump, it will sound like a table saw.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Veteran Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    x2^^
    if it doesn't sound like it a table saw (mine does lol) it's probably the power steering- check fluid- sometimes all you have to do is add a small amount and the sound goes away instantly
    Veteran Member Three Rings pismojeff's Avatar
    Apr 10 2004
    Bend, OR
    yeah, does not sound like secondary air pump. I just had mine replaced. did not make noise based on turning the steering wheel...
    2017 Audi Q7 3.0T
    2000 Porsche 911 Carrera
    RIP: 02 S6 - H&R springs, 19 BBS LM reps, RS6 front my ride
    Jan 19 2009
    Columbus, Ohio
    Thanks for all the replies! i checked power steering fluid and its very low. doh. should have thought of that myself.
    Should i drain it all out or just top off?
    Oct 24 2009
    2011 X3
    CT / RI
    flush the whole thing. Cant hurt right?
    Here is a little diy for yourself to use if you decide to go that route
    http://www.audipages.com/Tech_Articl...r/psflush.html
    Apr 21 2008
    Central New Jersey
    Glad you got it sorted out, now you have to figure out why it lost fluid.
