Results 1 to 7 of 7
    Mar 22 2010
    03 SILVERADO SS TOO MANY PARTS TO LIST, 2001 SUBARU OUTBACK (ONLY ECONOMICAL CAR)
    Salisbury NC
    center differential removal instructions
    I am going to be doing the 4:1 center diff swap tomorrow and my mechanic has never done it before and just wanted to see if I could find a write up to get it done quicker. I have searched everywhere without and luck. Does anyone has a step by step of this or any instructions. Thanks
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    I went to the Stasis Engineering website, and the center diff page has a 'how to install' with the page being http://stasisengineering.com/Admin/P...%20install.pdf. JHM also has some info on the 4;1 differential, with their http://jhmotorsports.com/shop/catalo...only-p-46.html. I hope these help... - Jim
    Mar 22 2010
    Salisbury NC
    thanks!
    Mar 03 2006
    WA
    It's pretty easy. Remove the driveshaft and the bolts holding the center diff housing on. Pull and replace the center diff and add transmission fluid as required to replace what leaks out.
    Don't be surprised if your new 4:1 diff makes vibration and clunking noises during low speed turns, mine does and it irritates me a bit, but the car handles noticeable better in the twisties, with much less understeer on the throttle.
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    its weird people get vibrations i had jason at jhm do the install and i have no clunking at low speeds or anything like that
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Quote Originally Posted by QWKDTSN View Post
    It shouldn't be making vibrations or clunking noises. Something's not right down there.
    Senior Member Three Rings Tarmac's Avatar
    Oct 10 2008
    b5 s4 nogaro
    Perth Western Australia
    What can one say? All my research point to the same response, time & time again most people say the same thing about clunking noises during low speed turns.
    I imagine the differential installation in an B6 A4 will be the same as a B5 S4 installation ???
    BTW if all goes to plan my JHM Center Diff will soon be at my front door
    B5 S4 Nogaro
    AKA: b5 s4 biturbo
