Results 1 to 25 of 25
    Senior Member Two Rings kengvang's Avatar
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    compound charging
    I was just woundering why no one has tried to come up with a compound charging system for our car? Can't we run larger turbos and feed it into the pes g2 supercharger system for the 2.8l? This idea was stuck in my head for a few days and i did some looking around and thought this might be possible. Found a link to a kit that makes big power with a set up like this. Let me know what you guys think about this idea.
    http://www.hotrod.com/techarticles/e...its/index.html
    http://www.europeancarweb.com/featur...ear04_zoom.jpg
    http://www.robsaudiworld.com/G2_installed.jpg
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Veteran Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    I have enough trouble keeping the car running with only turbo issues to deal with....
    That being said hot dam! that would be cool...
    make it happen!
    Nov 14 2006
    600hp glorified Beetle, Tacoma, motorcycles
    Renton, WA
    You can make more power that is more reliable, that weighs less, and costs WAY less with just turbos.
    Not that there's anything wrong with doing something ridiculous like that, it's just more of a "hey, look at what I can do!" thing than a real performance thing.
    -Darrick
    No more Audis, but I can't seem to leave this place.
    Apr 01 2009
    Iowa City
    i want to know who makes that supercharger kit!!!!!
    2000 Audi S4, Imola, Stage3, E-voms intake, Borla 3in cat-back, APR dp's catless, APR turbo kit, Stage3 Clutchmaster 6 puck, Fidanza flywheel, APR snub mount, AWE tuning trans-stabilizer, Pioneer headunit, Boston speakers, Viper alarm, OZ 18's, BFG KDW2's, APR Bi-pipe, Eibach/Bilstein suspension, VAST water/meth, JHM short throw with JHM linkage upgrades, JHM FMIC, 034 phenolic spacers, ECS tuning coilovers, Statis 4:1 mid diff.
    Established Member Two Rings jwk2w's Avatar
    Jul 02 2008
    '00 Nogoro S4, '82 280zx
    Hot Springs,Ar
    I've been thinking about this for a while now. I just don't have the money to pull it off.
    Vast 800hp or 1000hp kit with a supercharger to go along with it. You might no even have any turbo lag with that set up.
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    yeah, i was thinking the same thing. go with big turbos and use the supercharger to help spool and compound the boost so less boost pressure is needed to make the same horse power.
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Quote Originally Posted by derek072887 View Post
    what, the PES G2 Supercharger for the 2.8 a4?
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Looks like it would be a plumbing nightmare in an already tight engine compartment.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Well since this is just an idea, would putting on the supercharger on a k03 or k04 car make more or equal power with compound boosting? you can run the turbos at like 15-20 psi then into the supercharger to compound it to 22-27psi. this setup can also use water/meth injection too.
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Quote Originally Posted by TighTT View Post
    might have to run a stand alone engine control managment to run two intakes (one into the each turbo) then from the turbos to a (2 inlet to 1 outlet) frontmount intercooler then from there up to the supercharger. That doesn't sound like a lot of piping to me.
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Jan 31 2010
    S-Line A6
    East Haven, CT
    just buy this and buy my Cobra and your need for compound boost is filled
    1000+ HP on stock block, enjoy
    note, 4 people in the car to keep it stable on the dyno
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by kengvang View Post
    Um....OK.
    50% Blood
    50% Sweat
    Jun 22 2009
    Dundalk, MD
    LOL... It's called nitrous, and you don't have to run 80 feet of charge pipes, and you dont need a twin intake standalone system
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    please look up turbo efficiencies, and then look up the roots/screw efficiency. then rethink it.
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    This is a terrible idea. If you're going to do it then make the supercharger feed a large turbo.
    The PES unit sucks btw. You're much better off just running a large T4 twin scroll single with an HTA wheel.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Oct 08 2008
    MA
    Quote Originally Posted by [email protected]. View Post
    That's the spirit!! I wish more b5 guys used spray, it's a fuckton cheaper then quadruple turbo setups with 10 gas tanks, 4 meth pumps and an RS4 top end.
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Quote Originally Posted by sdoherty_tjm View Post
    seems this type of setup works pretty good to me! Yeah i know the PES system sucks ass, but to use the intake manifold setup and a screw type blower could be better. like i said, just a thought; trying to think outside the box.
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Veteran Member Three Rings Outkasted's Avatar
    Feb 12 2004
    01 986 Boxster/ Unrestricted Hayabusa
    Thought about this idea also. There is a maf splitter you can buy to run two intakes of the turbos, feed those to a twin entry single out front mount intercooler and then to the pes supercharger. The plumbing wouldn't be too bad but who has the cash to try an idea they thought of reading another unrelated car magazine.
    Always looking for the next project
    Active Member Three Rings
    Jun 16 2007
    Melbourne
    I had a G2 on my 2.8; was great fun.
    Anyway, if you managed to fit it on; and it is 100% possible, it would greatly reduce the spooling time of the turbos. I wouldn't be surprised if RS6's hit max boost at 2500rpm with the aid of the G2.
    Still, you simply wouldn't do it; it will hardly benefit peak power, but simply reduce spool time. Doesn't seem worth it.
    Veteran Member Four Rings DESPOT D S4's Avatar
    May 09 2010
    8S TTRS
    TriState
    pes tuning is a very good reputable company i have yet to hear anything negative
    @iruinaudis
    B5 S4 daily
    8S TTRS fun car
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Quote Originally Posted by DESPOT D S4 View Post
    i didn't mean any dis-respect, but it would have been better using a screw type charger instead of the m62 roots style. the screw style has a better eff range and less use of crank power.
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Quote Originally Posted by groovetek View Post
    well, think about it, you can get full boost sooner and run the turbos at less boost. this would help turbos last longer and still have all the fun right?
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Veteran Member Three Rings pohsib's Avatar
    Jan 04 2009
    Vancouver, BC
    In Japanese but its a Twin-Charged Nissan GT-R. 2 stock turbos feed 2 Rotrex Superchargers.
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    Quote Originally Posted by pohsib View Post
    yeah i've known about this setup for the gt-r. Those are centrifical style superchargers and needs to "ramp up" to make power. Those are just belt powered turbo's whichs works better when the rpms are up, but with the roots/ screw type chargers, you get that "almost" instant power at very low rpms.
    2000 S4 Tip
    GiacX
    K&N Filter
    N75 Race Valve
    Piggies
    Custom Exhuast
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    PES has been known to blow up blocks and not offer good customer support. Look at the B6 3.0 forums, and some B6 S4s.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
