Here is another offering from us for your RS4. Due to our recent RS4 in house R&D car purchase and how well our B7 RS4 drop in replacement rings have been selling we felt this product would do well. And yes we will be bringing more and more RS4 products to market, we have to max our RS4 out like we did with our S4. We have had these on our car already for quite a while and they definitely perform better than the OEM rotors our car came with.
Here they are in our online store -> JHM B7 RS4 380mm Front Big Rotor Kit
CURRENTLY ON PRE SALE AS OF 9-29-10. WILL BEGIN SHIPPING IN 3 to 5 weeks from this date. - $650 intro price as part of this pre sale.
WHY PAY $750 TO $900 FOR A COMPLETE NEW SET OF FRONT ROTORS FOR YOUR B7 RS4 WHEN YOU CAN BUY THIS KIT AND REUSE THE ALUMINUM HAT YOUR CAR COMES WITH WHILE ALSO GAINING 15MM IN DIAMETER FOR BETTER BRAKING PERFORMANCE???
Shaves 5lbs of unsprung weight from the front of your car while increasing the diameter of the rotor and braking performance, plus they bolt on just like stock! This is great alternative to replacing your complete rotor with OEM parts when your aluminum hat is reusable. You upgrade to a 15mm larger rotor for less than heavy stock replacments! We also do away with the annoying crack prone holes and sell these with quiet slots.
Stock vs. JHM
-Rotor Weight: Stock = 24lbs(each), JHM = 21.5lbs(each) - 11% LIGHTER, 2.5lbs less each (5lbs total)
-Rotor Cooling Air-gap: Stock = 13mm(.512"), JHM = 18.5mm(.728") - LARGER for better cooling
-Rotor Cooling Center Fin Design: Stock = Straight Fin, JHM = Airfoil - MORE EFFICIENT for better cooling
-Rotor OD: Stock = 365mm(14.4"), JHM = 380mm(15") - 4% LARGER for better caliper leverage on the wheel
-Rotor Thickness: Stock = 34mm(1.34"), JHM = 34mm(.1.34") - SAME
-Bolt pattern: - SAME (fits on the OEM center hat just like an OEM rotor would)
INCLUDES: 2 - JHM 2-piece Lightweight 380mm Big Front Rotor Rings, 20 - New HD 6mm allen bolts, 20 - New HD 6mm washers, 20 - New Self Locking (swedged) nuts - New Longer HD caliper bolts, 4 - New Stainless steel caliper shims, 4. (Each rotor weighs 2.5lbs less than stock for a total of 5lbs weight savings.) 11% lighter!
ONLY AVAILABLE SLOTTED: Our slotting is quiet and not noticeable.
Outer ring specs:
We worked closely with a race brake manufacturer that supplies many NASCAR racers and a couple major brake kit companies. Due to their expertise we chose to have them build us the outer rings to our specs to fit the B7 RS4.
The install is just as straight forwards as our 365mm drop in rotors, the only difference with this 380mm kit is that you need to install our supplied stainless steel shims between the caliper and spindle (see pic above) and our supplied longer bolts.
