Ok guys, I am finally breaking down and posting my issue. I have searched and read as much as I can handle at this point.
Now, first let me explain my car and mods. I have a 2001.5 TIP. I have a custom VAST tune for a stock set up, ie. turbos exhaust ect. But I have Evolution Motorsports DV's. The tune is very aggressive! Pretty much maxing out the turbos and injectors and everything else. Boost peaks at 20-21psi then tapers to about 18psi. Great tune by the way, pulls insane for just having a tune and being a TIP!(L box ecu with vast tune for sale fyi)
My driver side turbo started to whine like a supercharger once above 5psi or so. With the turbo whining, it has boosted normal, pulled normal, seemed like there was no problem. Just was like I swapped my turbos for a easton blower...?? Whatever. On a side note, I have been seeing oil under my S on the driver side. Nothing serious, just some spotting...my car is a she by the way.. I also have noticed a modest amount of oil on the turbo outlet pipe, long before the turbo started singing. I figured it was just a small valve cover gasket leak dripping on the turbo, and would take care of it soon enough.
Now on to the issue. 2 weeks ago I have noticed a few new things.
1) During high boost I hear a loud sound that I would describe as rushing air. It almost takes over the loud supercharger like noise. It is also combined with a high pitched squeal. After 1 maybe 2 seconds of this sound the boost cuts down to 5psi and never goes above untill I shut the car down and restart.
2) When I let off of the gas there is a very high pitched noise. Like when slowly letting air out of a balloon. This noise is constant as long as the motor is in vacuum, or just the slightest amount of load on the motor, when pressing the gas. It also makes this noise when stoped or idle but tends to stop sometimes after sitting for a moment.
I have not had time to pressure test or pull any codes since this started. But I have planed some time over the weekend to do this. I am at work right now and cant stop thinking about what is causing these two new issues. Like I stated at the beginning, I have searched and searched looking for anything that might point me in the right direction.
Forgive the length and detail of this post. But, I felt it to be necessary in order to receive the best response and help needed from you more experienced AZ members.
Thanks to all who help,
-T-
