Page 1 of 3 123 LastLast
Results 1 to 40 of 112
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    My Oil Problem thread
    Yet another oil consumption thread!
    So 300 miles after adding my last quart of oil, I'm in need of adding another quart.. Yes I did search, found a thread on B6/B7 S4/RS4 section only.. Anyways, last time I added a quart was after 600 miles and so far it has only been getting worse and worse. I only put 93 octane gas in, I haven't driven hard, gone under WOT since the last quart. Always let it idle for a minute before driving, in the mornings usually longer, and before turning the car off I let it idle as well. Taking it to the stealership today hopefully, if not tomorrow. Any ideas on what the F is going on here? Will post pack as soon as I take it in/hear from the dealership. TIA
    ***EDIT/UPDATE*** Cars going in Monday, let my mother call to handle this one, since the passed 3 times jack s*** has been done about it. I might be coming home with a different A4 apparently.
    ****--Oct 12th Update-******-Was told by the dealership to check my oil here and there, have had it it back for a a couple weeks now and the problem seems to still be occurring.. It's going back in tomorrow, they're going to check it out and see what is going on this time.. IMO They will replace the piston rings this time around, since they've already replaced the PCV/valve cover.. Lol..
    2nd update.. So instead of waiting until Monday to take it in, Audi opted to send a flat bed in free of charge and have it taken in, Now begins the waiting..
    RIP QG TI B7 A4
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Mysterious man... Mine eats oil also
    Mar 09 2010
    North E. Jerz
    Lemon-Law? I've taken it in 3 times before this and, as stated above, only gets worse =// I wouldn't be worried so much if it was like it used to be.. 1qt/1000mi, but since it has been only getting worse, something is clicking in my head saying there's a bigger problem here. I'm no mechanic, but this shouldn't be happening as far as I know heh. I hate mysteries >< Will post back ASAP with results hopefully
    RIP QG TI B7 A4
    Mar 09 2010
    North E. Jerz
    Car went in last night, it was taken apart first thing this morning ^^
    They wanted to put the stock airbox on because they thought that the Carbonio was causing oil to be used quicker? Not sure if that makes sense to you guys, anyways should have an answer hopefully today, if not sometime this weekend for sure. It's good to know people ^^
    RIP QG TI B7 A4
    Senior Member Three Rings deeznuts's Avatar
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    First mistake is not putting in the stock box before it went in. They could fuvk u over for that. Whivh dealership are you going to, town audi or meadowlands audi? And the lemon law doesnt apply to u bc u bought your car used and unless the person before u has documented service cpo's about the same thing...lemon law will never apply. Keep me updated because my car burns a lot of oil too. If they fix it under warranty im going to bring my car in right after you
    Koni ss, creative test pipe/downpipe, britalman exhaust, greddy fmic, rs4 sways, apr stg II, a lot of adrenaline
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    tell them to put a valve cover on it and ship it. retards there?
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Mar 09 2010
    North E. Jerz
    Took it to town audi, Ahh I see, didn't know that. From what I have been hearing, seems like it will be fixed under warranty. And yes, it seems as if they are retards there.. Hopefully 4th times a charm. Lol. Will post back when I get some news.
    RIP QG TI B7 A4
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    Well at least its under warranty that's good...I see u driving through tenafly once in a while- your cars clean-time to lower it!
    Established Member Two Rings daudic's Avatar
    Jul 06 2009
    2007 A8l. 2003 TT Roadster. 1985 Yamaha Vmax!
    Lancaster/Ohio
    I recently read a post out here by an Audi tech who said that the baffles underneath the valve cover come loose or degrade allowing oil to pass through the PCV then into the turbo. It burns slow enough to not smoke, but fast enough to cause people to fill up quite a bit. He said that it is the main cause and the easiest fix.
    Senior Member Three Rings DocJ's Avatar
    Nov 24 2009
    Bergen County, NJ
    is audi meadowlands a mod friendly dealership?
    -Jeff
    Mar 09 2010
    North E. Jerz
    Haha thank you deez, I think I saw you driving around Closter a couple weeks ago, AWE quad tip?? I know, it needs to be lowered soo bad.. Anyways, just heard from my mother saying that they are replacing the intake manifold/doing oil change. Free of charge. I could be wrong, not sure if she meant the intake manifold or meant something else but who knows.. I'll be back with more news hopefully soon.
    RIP QG TI B7 A4
    Established Member Two Rings jma57's Avatar
    Jun 20 2010
    Pa
    Yes, please post back. It's generally bad baffles and or bad rings. I wonder if driving habits have something to do it.
    Case in point: My car uses a little oil, about 2/3 of quart in 1400 miles when mostly commuting to work in stop-n-go traffic, not too bad I think. I changed the oil and filter just before Labor Day and then drove up to CT and back, about 400 miles of highway driving(70-90 mph) and as far as I could tell it didn't use a drop.??
    Good luck with your fix, let us know.
    Mar 09 2010
    North E. Jerz
    ^ Have heard mixed comments on driving habits, yeah that's what I have been hearing, baffles, rings, seals, PCV, etc. Will get detailed information ASAP.
    RIP QG TI B7 A4
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    Quote Originally Posted by DocJ View Post
    so far theyve been good with that...think so..
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    Quote Originally Posted by Leo14 View Post
    nope, Britalman quad..and intake manifold? hmm
    Mar 09 2010
    North E. Jerz
    Ahh well, still quad tip haha, looks/sounds good nonetheless. So they are putting the stock intake back on, didn't mean intake mani, thats what I heard from my mother.. Shes an idiot and thought that was the intake.. Will keep regularly updating you guys. Everything is being covered, no charge. They're also fixing the corroding paint on the corners of my trunk
    RIP QG TI B7 A4
    Mar 09 2010
    North E. Jerz
    ***UPDATE*** Looks like ill be getting the car back tomorrow, will post exactly what they fixed.. From what I have been hearing is that if it isn't fixed, new engine..? Beats me, I'm just happy I'm getting it back so soon.
    RIP QG TI B7 A4
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Definitely do...interested to hear what they found.
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    woo deff keep us updating, would love to know what they did to fix it :)
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Mar 09 2010
    North E. Jerz
    Hey guys, got the car back today, well yesterday actually. Didn't get a chance to hop on AZ and let you guys know what they fixed, anyways on to what they fixed.. So last time I had it in they did replace the valve covers, and this time around they replaced the PCV... Got hooked up with 6 qt's of oil too.. The person I spoke with told me if the light comes on anytime soon, flatbed it in and again they will try to fix it. Lol. They also took off my Carbonio/034 Inlet Hose as well :( :( Car feels so.. slugish now.. Anyways, it was all fixed under warranty, which they gave back after realizing my intake wasn't causing the oil problems from the last few times.. Cars going back in monday to fix a sh** paint fix on the corner of my trunk ^^ Guess thats it, I'll let you guys know if the light pops up again, and when I take it in/what they fix etc etc..
    PS - the option of a new engine is still in mind by audi apparently.. Doubt that will fix it though, he said there really is no known fix for this problem and Audi is yet to recognize it.
    RIP QG TI B7 A4
    May 29 2007
    are they kidding? audi has a known issue with 2.0t and oil consumption. pcv/valvecover, then rings.
    Senior Member Two Rings arbaz's Avatar
    Feb 01 2009
    mothers always get shit done
    ///B7 A4 3.2L Quattro Tip
    Mar 09 2010
    North E. Jerz
    ^ that they do haha
    The guy was saying the same things your daddy, pcv/valvecover/rings.. I just hate them for taking my intake/hose out =//
    RIP QG TI B7 A4
    Mar 09 2010
    North E. Jerz
    Bumping so I don't need to make 1000 threads about the same thing
    RIP QG TI B7 A4
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    why didnt you ask for it back haha?
    Senior Member Two Rings rowyourown's Avatar
    Jan 13 2010
    New York
    nice, they charged me $70 to tell me that my sirius module isn't the right one even though dan at europa parts swears it is.
    Eibach springs, Bilstein sport shocks, GIAC, 034 HFC, RS4 rear sway, V710s, Hankook Ventus V12 235/40/18
    Mar 09 2010
    North E. Jerz
    Quote Originally Posted by deeznuts View Post
    If you mean the intake and hose it was in my trunk when I got the car back last time =P
    RIP QG TI B7 A4
    Jul 27 2009
    '15 S3
    Boston
    Were they going to perform the oil consumption test on your car? My dealer did Part I and I'll need to bring it back in after 630 miles, when they plan to replace the piston rings.
    Mar 09 2010
    North E. Jerz
    They did say the last time I had it taken in that the next time they would perform the oil consumption test. Have you had anything else replaced beforehand? PCV, etc?
    RIP QG TI B7 A4
    Jul 27 2009
    '15 S3
    Boston
    Actually just went in last week for my 35k maintenance. Along with Oil Consumption test part I, they replaced my PCV, Timing Belt, & Tensioner.
    Mar 09 2010
    North E. Jerz
    Cars going in Thursday rather than today. How many parts are there to the oil consumption test? Going to have them do it on Thursday
    RIP QG TI B7 A4
    Mar 15 2010
    Kansas City MO
    I just finished part two of the oil consumption test. I dropped car off in the morning and by 2:00 I got a call telling me they were going to replace the rings. I don't have the actual data from the test, but once I get it I will make sure I post it.
    From what I could tell by looking at the dipstick, I burnt at least 3/4 quart in ~575 miles.
    Jul 27 2009
    '15 S3
    Boston
    Two parts. You have to wait for 630 miles to bring it back for part II
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by breezer View Post
    How long did they say they needed to keep your car in order to replace the rings?
    Mar 15 2010
    Kansas City MO
    I was told 1 week so they could do the work and then test drive it. The dealer had to order the parts, so I have the car back for a couple of days.
    Jul 06 2009
    Lancaster/Ohio
    Request an awesome loaner!
    Veteran Member Three Rings saizero's Avatar
    Aug 11 2009
    Chicago
    Quote Originally Posted by daudic View Post
    Agreed you should get a loaner, when I took my car in for HID repairs they let me use a really nice 2010 A4 Brilliant Red Avant. Wish the newer avants came with a manual trans though...
    Current AWE Boost Gauge : STaSIS catback : 034 HFC : ECS Snub Mount : Upgraded Piston DV : CTS Turbo Catch Can : ER FMIC : DTM Front/Rear Votex Side Skirts : Stasis/Ohlins SL Coilovers
    VAGCOM Owner
    AKA: vmSAi
    Jul 27 2009
    '15 S3
    Boston
    Yeah that's what I was told as well.
    Mar 09 2010
    North E. Jerz
    So they have had my car since the 12th of October I believe? Just went today to pick it up because they said they could find nothing wrong, after driving it 400 miles, and they also said they were supposed to fix some chipping paint/clear coat on the back of the car.. They didn't, so I had to leave it there until they fix it.. Maybe the PCV did "fix" the crazy oil problem? Idk. Sucks not having your car for this long..
    RIP QG TI B7 A4
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    damn leo, you are going through the ringer, and you seem pretty laid back about it i wish most people had your patience
    hold strong, i would say after the 4th time being as rational as you've been you should ask them about the lemon law, i mean your dealership is trying, and it seems like nothing is working so the best case scenerio may just be to replace it
