Hello everyone!
Thanks for the replies again. I apologize for the late response but it took me a while to figure this one out, I wasn't really sure for a long time. AudiA4Turbo, you're correct about the oil problem! It isn't a problem of oil "level" perse, as I will tell you soon.
After checking your message, I checked my oil level a week later. I saw that the oil level was completely full, but still having the knocking problem whenever I accelerate hard I decided to add a tiny bit of oil. Wala, the knocking almost completely disappeared. A week later, the knocking came back. I added a little bit a oil again, knocking almost disappeared again completely (what I mean by almost is that it was knock once to three times total on a hard acceleration from gears 1-3/4; as opposed to like 1/sec or 2/sec knocking in each gear).
So thanks to you, I now know it's an oil related problem and not a turbo problem. I'm thinking I may have sludge or maybe something is inhibiting my oil pressure. I've done some research and I have read that it may be something called the "oil pump strainer" that is clogged. My VW mechanic puts regular oil filters, but i doubt that is an issue with the knocking but i'm going to make the switch back to large oil filters.
Would you guys suggest a seafoam? I think the oil pump strainer is really hard to get to, but would it be worth it (and a correct thing to do)?
Thanks again, I will definitely post the solution to audizine to add to the database of solutions on this great forum community.
