Results 1 to 15 of 15
    Established Member Two Rings -yz-'s Avatar
    Sep 29 2010
    Washington, DC
    Question on 05.5 -06 S4 Purchase
    I'm in the market for a B7 S4 with around 50-60k miles on it. Found a number of them for private sale and wanted to know how these cars are up to 75-100k miles. At around 60k should I be asking them if they serviced any specific part of the vehicle? I'll end up having to fly and buy so wanna make sure I'm asking the right questions about these cars.
    I'm a long time VW guy, over here from Vortex. I am selling an 08 R32 now and since previously had a 2006 Gli. I've never had any maintenance issues with either of the newer VW's but then again neither of them exceeded 35k miles. Just want to make sure the 05.5 -06 S4 is a solid car.
    Thanks.
    Mar 19 2006
    Crimea
    I'd make sure you buy it CPO'd if you're planning on owning it until 100k.
    Sep 29 2010
    Washington, DC
    So never buy one of these vehicles that is not a CPO?
    Oct 16 2008
    97 Jetta VR6, 87 5000 Turbo Quattro, 05 S4 Avant, 98 Cherokee, 83 GTI, 06 Sierra 3500 Duramax
    Parker, CO
    i'm not very experienced, as i've only had my early 05 s4 for a few weeks, but on mine around 40k it was due for a serpentine belt, valve cover gaskets, drain plug seal on the thermostat housing, and control arm bushings..just a few things to keep in mind if you aren't doing the work yourself..and like i said i'm not very experienced with the s4's because i'm a long time vw guy as well..but there will be more chiming in i'm sure
    Sep 29 2010
    Washington, DC
    Quote Originally Posted by JarrettJettaVR6 View Post
    Good point, I'm a long time VW'er as well. One particular car I'm interested in is for sale on these classifieds and I've spoke to the owner who has already replaced what you mentioned above. He's got a long history of maintenance records as well with the vehicle. The vehicle has around 61k on it and I think I could get it for a good price. The concern obviously is driving it for a few months then BAM, problems. Might have to go the CPO route just because that will be in the back of my head.
    Dec 08 2006
    Newark, Delaware
    Quote Originally Posted by wsf0817 View Post
    great, so it will be cpo'd for another 6-18 months, then out of warranty - not a good deal if buying the model year that he wants. 6yr/100K whichever comes first, on a 05.5 car means that it's only good til 2011 if your lucky. in other words, i disagree with above statement. are you really going to use thousands of dollars in warranty in the next year before it expires....CPO may be more worth it if you buy a newer model year. i bought 06 aniv edtn in 07, cpo'd, but nothing broken under warranty yet.
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Don't be too scared off by the above posts. I'm at 75k on a 05.5 and all is strong but I do all the maintenance. Around 65-75 you do have some work to be done, but much is covered in DIY threads that can be done yourself if you want. Just stay away from the 04 (problems with some of the early build 04's) and get the 6MT ;-)
    IMO the extended warranty isn't worth it hardly at all, especially if your planning on doing mods. The aftermarket warranty I was quoted was around $4k and I can buy/pay for a lot of work before I hit that price. These engines are strong they just need to be taken care of and good regular maintenance done.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Sep 13 2008
    Western Chicago Burbs
    I would find an 06 if you can versus the 05.0. the o6 will have the 60/40 rear differential, Symphony II+ radio, and some other stuff
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    based on my experience, i would not buy another used audi unless it was CPO.
    Jan 14 2009
    Audi's
    I've had my car for two years put 20k on it and its been very good other than vavle cover gaskets and aux radiator. The only other things Ive done were just routine maintenance.
    Also check this thread out
    http://www.audizine.com/forum/showth...-need-to-know.
    Good luck
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    I've put 35000 miles on my 05.5 in the two years I've owned it (now at nearly 65000) and haven't had any problems beyond valve cover gaskets
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Established Member Two Rings nfs1000f's Avatar
    Sep 22 2010
    1987 Honda Hurricane 1000. Gone: 1986 4000, 2001 A6, 2005 B7 S4
    VESTAL, NY
    Quote Originally Posted by whartung View Post
    Just bought my 2005.5 and can only hope for the same.
    Sep 29 2010
    Washington, DC
    Quote Originally Posted by B6JoeS4 View Post
    So is the 2005.5 the same as the 2006? You said 2005.0 so I'm assuming you're talking about the B6 body?
    Feb 01 2007
    Quote Originally Posted by -yz- View Post
    05.5 is aesthetically the same as an 06 but mechanically the same as an 05.
    Sep 24 2010
    Irvine, CA
    Same here. Just bought my 2005.5 S4 with 6MT last week here in So Cal. She had 75k mileage when I picked her up. One owner.
    Quote Originally Posted by nfs1000f View Post
