Hello all,
I have had an issue with my Audi Symphony radio. I had the clutch replaced on my audi unfortunately just one day before I moved to Oklahoma. The work was done in the SF Bay Area. The radio was in safe mode and there was no way to have the work done before I moved. I researched and learned a great deal about the Symphony radio. I figured out the radio code from my owners manual. I followed the directions exactly and the code did not work. It just flashed and stayed in safe mode. This was really annoying because I drove 24 hours without a radio. I tried to take out the fuse in the fuse box to see if that would reset anything. Nothing. I called the Audi USA to make sure I had the exact code. They gave me the same code I already had and it still didnt work. I let the radio stay on with the key in the ignition for several hours as one person suggested that the "chip took a long time to heat up." I also tried the one hour reset with the key in the ignition many times without it working. Even on my 24 hour drive, I tried it several times with the exact code and nothing... Does anybody know if there is possibly a different code? The radio was working fine until I had my clutch replaced. If anybody has any suggestions please help me. I would greatly appreciate it.
Thank you
