Results 1 to 20 of 20
    Senior Member Three Rings Vegas34's Avatar
    Mar 04 2008
    2001.5 Nogaro/Alcantara/6speed
    Vegas
    I have the day off, can I get this done?
    - Replace drivers side broken tranny bracket
    - Replace cracked tranny mounts with 034 Street Density mounts.
    I done about all the mods/maintenance for my car, but this will be the first messing with jacking the tranny up, etc. Does anyone have a link to the DIY for tranny mount replacements AND will it be easy to do the bracket while I'm in there.
    And yes, I've searched around, just hoping my friends on here could help me with some quick info as I ACTUALLY have a DAY OFF! :-) TIA.
    b5 6-speed.
    Rob B. - Kansas City, MO
    2001.5 Nogaro S4 | 6 speed | Alcantara | DD with no major mods
    2008 A4 2.0T | Wife's car
    Established Member Two Rings vdub203's Avatar
    Jun 25 2007
    east haven ct
    im preety sure its a simple job and you wont have a prob witgh gettin it done in half a day or quicker
    05 s4 daily driver
    04 m3 dinan s1 jb/ir raven motorsports cage tckline bbs ect
    00 brilliant black s4. magnaflow, kw coilovers, awe tuning, piggies, bbs ch. ect ect..sold
    01.5 nogaro s4. apr catback, kw coilovers, some wheels with a lip..sold
    tt225, tt180, 97 m3, 95 m3, 94 skyline GTR .....all gone
    Veteran Member Three Rings Quattro_2.7tt's Avatar
    Jan 22 2009
    2007 S8, 2004 A6 4.2 6 MT swap, 2008 A6 S-line 3.2,
    Scottsdale, AZ
    i want to do my trans mounts soon too. I wanna see a write up.
    Current: 07 D3 S8 V10 - stock.
    04 C5 A6 4.2Q 6 MT swap and a lot more mods.
    08 C6 A6 3.2Q S-line - stock
    Sold:
    05 B6 S4 6MT
    01.5 B5 S4 6MT
    00 B5 S4 6MT x2
    99.5 B5 A4 1.8tq 5MT
    05 A6 3.2 Quattro
    Veteran Member Four Rings cu52's Avatar
    Dec 11 2008
    Denver Metro
    OE1 trans removal pdf. Has some of the info in there.
    http://www.box.net/shared/3zkn3gj08z
    13 Tundra SUPERCHARGED
    01 B5 S4 Avant, C5 RS6, 18 SQ5
    Gone:
    03 RS6, 01 605 Tial Avant, 00 S4, 01 S4 Avant, 01 Imola, 00 Hibiscus, 04 4.2L Allroad 6 speed swap, 03 allroad, 04 Audi Allroad 6MT 2.7T ST3!, 04 Allroad TIP, 02 Allroad MT6 2.7, 08 Toyota Sequoia, 04 Audi S4 MT6, 01 S4 Casablanca White 6MT , 04 VW GTI 5MT, 03 A4 Avant 3.0 6MT, 09 Tundra CM, 11 Tacoma DC, 02 A4 Avant 3.0 Tip, 01.5 S4 Avant tip GIAC stage 3-, 00 S4 6mt
    Mar 04 2008
    Vegas
    thanks for the link...I hope doing this whole thing gets rid of the noise over small bumps I'm dealing with...
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    Do you have to take the whole tranny out to do this?
    Dec 11 2008
    Denver Metro
    Quote Originally Posted by sqitis View Post
    No
    Gone:
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    I was under the impression this is a pretty quick/straight forward job?
    Mar 04 2008
    Vegas
    "No "
    so just jack the tranny up a bit once the car is on jackstands, and I should be able to replace all 3 parts? i'm about to start as the car is finally cooled off...
    Veteran Member Three Rings Dubluv11's Avatar
    Jan 08 2010
    00 S4
    Quote Originally Posted by Vegas34 View Post
    "No "
    yes...put a piece of wood between the jack and the tranny though... dont jack it to the point that it moves alot though...just enough to support it from falling
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Should be an easy relatively quick job.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Two Rings jms-4's Avatar
    May 14 2009
    2000 Audi S4, 68 Mustang
    Renton, WA
    It took me around 45 minutes to replace my trans mounts. Very easy just follow the tips given above. Get car on stands, put jack under tranny to support it, you'll have to remove some heat shielding stuff (that was the hardest part as there is not much room up in there), and remove old mounts, slide new mounts in, re-attach the 3-4 nuts to hold the heat shielding material, and voila. You're done.
    Not sure on the other part you mention, though.
    Jeff
    2000 S4
    Revo w/SPS3
    AMS TBB, Stern snub mount, Apikol Rear Diff Mount
    3" custom exhaust, Minor lemmi tweaks
    ST Coilovers
    710N, EBC Slotted + Dimpled
    Incognito Piggie Pipes, 034 Density Trans Mounts
    Voodoo MBC Ceramic in MBC only mode
    other stuff
    Mar 04 2008
    Vegas
    Ok, the car is on jack stands and this bracket (not the mount) on the drivers side that is broken looks like a MOTHER to get to the top bolt. Any other tips? And yes, to replace the mounts with these 034 ones is going to be the easy part...
    Mar 01 2009
    manchester uk
    the actual brackets that bolt to the tranny will take a bit longer there is a heat shield and a few bolts to remove and a couple a bit akward to get too . if you had a very long hex key it would make it easier there is a small hole to put a hex key through to get to 2 of the bolts.
    Mar 04 2008
    Vegas
    I've got the jack (with wood block) against the tranny now, but am afraid to jack much pressure on it. I've got the bolts on the mount out, but the mount is still tight as hell in there. I guess I need to jack up the tranny some more? Thanks...
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Deactivated Two Rings
    Jun 30 2010
    Fremont, Ca
    Don't be afraid to apply a little pressure to the transmission with the jack. You will know when you can't go any further. I used this method when replacing the rear diff mount on my 95 S6 (which is also really tight) and it worked out fine. Good luck.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    easiest way to take the bracket itself off is by taking the downpipe off also (not hard at all hope u dont have the heatshields on em still) very easy and straight foward shouldnt take more than 45 minutes.to take off and same to install everything back. goodluck taking it off without removing the dp cause that top bolt is not east to get too with the dp right in front of it
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Sam@034 View Post
    +1, I have had a similar experience, albeit with a different platform.
    Also, now that the day is coming to an end, how well did things fare for you?
    Brandon @ VMR Wheels
    Mar 04 2008
    Vegas
    I got called to work in the middle of the job (it's the shits being on call most of your life) and just got home. All the bolts are out, but the tranny doesn't want to move up much when I jack it up with the wood in place. The whole drivetrain and exhaust move with it, so I'm stopping for a bit. If I have to remove the damn DP, I might as well do the piggie project now too...
    FYI for anyone with a broken tranny bracket (not the mount) it is NOT a 1 hour job to replace, it's a mother to get the top bolt out...
