Results 1 to 9 of 9
    Sep 28 2010
    ohio
    bearing, differential?
    New to the site had my 2001 s4 just hit 100,000 miles for a year now.
    when i drive between 55 and 70 i can hear a loud hum coming from the rear end. I believe it is from the passenger side. I tried swerving to see if it was a bearing but i could not tell. I had a sway bar link rub on my axle on the driver side and break recently. I replaced that and still have the noise. Tires are all good and wearing evenly. I have a small leak in the rear diff, not enough to even get on the garage floor just gets the case wet. I tried changing the rear diff fluid and there was no shavings in the oil and it still wines.
    car is currently getting a new radiator since it decided to break like everything else does in the shop and the repair guy didnt get to take it for a drive. He said there was no noticable play in the with the wheel so he didnt believe it was the bearing.
    My question is can it still be the bearing if there is no play in the wheel and whats the chances of it being the differential itself and how much will that run me.
    this car has done nothing but drain my pocket for a year straight. Id have got rid of it by now if i didnt like it so much.
    thank you ahead of time for the help.
    Sep 28 2010
    ohio
    bump
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Sounds like a bad bearing
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Sep 28 2010
    ohio
    can it still be a bearing with no movement in the wheel
    Established Member Two Rings AJ88CAB's Avatar
    Oct 04 2006
    Atlanta, GA
    Yes, you may not be able to feel movement even if the bearing is going bad...Do you have access to one of those IR temp sensing guns. You can get them for about $35 these days. Go for a 20 minute drive then immediately measure the hub and rotor temperature. If the pass side is more than the driver side it is probably the wheel bearing. If they are the same it might not be the bearing. Does the sound change with speed. If the sound doesn't change with speed it might not be the bearing. I don't know what a failing fuel pump sounds like on these cars but that is another possibility in the same area. Or a CV joint, but they usually don't hum. Also the drive shaft bearing, but that would be more from under the car. If your real adventursome you could put the whole car up on jack stands and run it and see if you can locate the noise. But I take no responsibility for your safety if you do:)
    aj88cab
    Marietta, GA
    2002 Audi S4, Silver, 6 Speed
    1988 Porsche 911 Cab
    1972 Porsche 914 (long term...really long term...restoration project)
    Sep 28 2010
    ohio
    it does change with the speed of the car and i know its not the fuel pump bc it doesnt stay when im not moving...i just keep praying its not the differential. ill see what the guys at the shop think.
    Jun 14 2005
    Anaheim, CA
    Ah, this is a tricky issue, a friend of mine was under a similar issue.
    For him, the sound got progressively worse fairly rapidly, which helped determine it was indeed the differential (unfortunately). As far as a wheel bearing going bad without any sort of play, I really haven't heard of it, but then again, when you hear about wheel bearings going bad they're usually far gone. If you notice the sound to increasingly getting worse, and there are still no tell-tale signs of a wheel bearing issue it may be better to think of the worse.
    I'm hoping the best for you, an internet diagnosis is pretty hard in this case! I'd say your best bet would be to take it into a well known mechanic and see if they can diagnose the issue for you.
    Brandon @ VMR Wheels
    May 04 2004
    00 BB S4
    York, Pa
    I was just about to make a thread. I have a similar situation with the loud hum from 60+ increases with speed but is pretty damn loud. Noise goes away when clutch is depressed or off accel. Off accel the hum turns into a whoom whoom whoom sound about every second. Just replaced a bad rear wheel bearing before this problem started, at the same time my mechanic flushed the rear diff fluid, but I have not checked the levels yet.... Let us know if you find what the issue is.
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Senior Member Two Rings TozoM8's Avatar
    Sep 17 2010
    Black on black 01 Twin Turbo S8, 6MT, built in SRX 01' allroad 2.7T
    Chicago
    It could be your tires. My A8 does that 50-60mph. When I swap tires it goes away.
