Results 1 to 7 of 7
    Senior Member Three Rings hcaudikeed's Avatar
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    Exhaust gurus needed
    I have a 99 2.8 a6. I got the car chipped by giac and was happy with the results. More torque down low. About 2 days after I removed the center resonator and though it sounds better, I lost all that low end torque I gained with the chip. So I'm thinking about doing the exhaust right this time.
    My cats are kaput and jersey no longer does mechanical inspections. So here is what I was thinking.
    Remove the cats, putting pipes in their place, followed by a y pipe with a single pipe through the middle of the car, followed by another y pipe and out to two flowmaster 44 series. I'm looking for more of a deep sound. I'd like it to be loud, have some backfire/popping, don't care much about drone, and want a proper amount of back pressure to get the low end torque back.
    Does my setup sound good or do you have any other ideas?
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    it will probably be cheaper to have them do dual straight pipes to the mufflers, instead of the y-straight-y setup you mentioned.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    I understand that. But I already lost back pressure and torque just by removing the resonator. Wouldn't I lose more by removing the cats as well? I want the y pipe to single to gain back pressure.
    Established Member Two Rings csh724's Avatar
    Sep 23 2009
    Douglassville,PA
    not to jack the thread but with the chip you did feel a noticeable difference in low end torque?
    99' A6 2.8Q Tip
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    Yes. And lost it by removing the back pressure the resonator caused. N/a engines, especially a smaller v6 like the 2.8 needs back pressure.
    Veteran Member Three Rings jeffp477's Avatar
    Jun 09 2009
    1982%20porsche%20924/%2005%20VW%20Touareg%20V8/2018%20VW%20Tiguan/%2717%20Triumph%20Street%20Twin/82
    temecula,ca(socal)
    if your gonna run a y to a single then back to y might be cheaper cos they are not gonna use extra pipes.. but they might charge you the y pipes... do a 2.5" to the Y then 3" single to compensate being a single exhaust then same exiting out the Y if u really like that setup.. then dont use a muffler for it to be loud, just use a pair of 6" to 12" resonator then put some tips on it.. guarantied loud.. or get some cherry bomb resonators..
    -jeff-
    c5union
    DIY Audi
    Audi Tech and tips
    psn:jeffp0477 gt5 whore
    Senior Member Three Rings MLFHNTR's Avatar
    May 29 2010
    '04 Allroad, '02 GTI
    Daytona Beach
    Cherry bomb FTMFW!
