Results 1 to 8 of 8
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Help, Maf problem again.
    Driving on the FDR, car loss all power and shut off. I unplug the Maf and car started again fine but no boost at all. Maf was replaced last week. A friend of mine said it could be the plug that goes into the maf not making that much contact. Well a least i didn't need a flat bed this time, what you guys suggest?
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Jan 29 2007
    08 S4 00 S4
    MD
    If it runs fine off the MAF, check for intake leaks. Large intake leaks.
    08 S4- Stock SOLD
    Feb 12 2004
    B5 S4
    Quote Originally Posted by mholme View Post
    Runs fine but theres no boost at all. Step on it and gauge goes to 0 psi like it hit a wall and nothing else.
    TEAM A.C.E. NY
    Jan 29 2007
    08 S4 00 S4
    MD
    Sounds like an intake leak to me. It's in limp mode, so you won't see any boost, but it'll limp you home.
    08 S4- Stock SOLD
    Feb 12 2004
    B5 S4
    Thanks, will look for codes tomorrow morning. Could the plug go bad also?
    TEAM A.C.E. NY
    Jan 29 2007
    08 S4 00 S4
    MD
    Anything is possible, but I'd start with a visual of the hoses and a pressure test. Obviously you can check the MAF wiring as well, but I'd be looking for a large leak first. You could still have MAF codes with a large leak, so don't assume the MAF is the issue if that's the case.
    08 S4- Stock SOLD
    Feb 12 2004
    B5 S4
    Thanks again man, will pressure test tomorrow. Is only stage 1 right now!
    TEAM A.C.E. NY
    Feb 12 2004
    B5 S4
    Maf is reading too low, pressure test is next.
    TEAM A.C.E. NY
