Results 1 to 2 of 2
Thread: HELP!!!!!
    Aug 15 2010
    Southwick, MA
    HELP!!!!!
    HELP!!!!!
    my car wont start... its a 1999 a4 1.8t quattro. no spark, replaced spark plugs and noticed that the plugs from the harness that plug into the coil pack had some wire that were missing the insulation. im not getting spark... what could have cause the wires insulation to break... nothing burnt but just cracked insulation and no spark. not sure how far back the isulation is cracked. suggestions on what cause this or how to fix it?
    Jun 30 2008
    Erie, Pennsylvania
    Firstly, props on including your year and engine. So many people forget that stuff, makes it hard.
    I'd check your fuses. Specifically fuse #29 or #32. I'm thinking you lost power to the coil packs due to a short in the coil pack harness.
    Do you get fuel or injector pulse while cranking (are the plugs wet)?
    Cracked insulation is caused by heat damage. Those wires put up with extreme heat from the engine and turbocharger. You can buy a repair harness that is premade or buy the coil pack connector pigtails and with a little work fab up your own.
    There was a TSB issued for the transverse cars (Jetta 1.8T, etc) from VW that described the official fix:
    http://www.squarewave.com/army/andre...b.97-04-02.pdf
    Here is the Jetta replacement harness which can be retrofitted for the A4 (probably the best solution at $50!):
    http://www.ecstuning.com/Volkswagen-...arness/ES7679/
    Or an aftermarket solution:
    http://www.034motorsport.com/ignitio...l-p-19338.html
    Or another aftermarket solution:
    http://uspmotorsports.com/product_in...roducts_id=500
