Results 1 to 16 of 16
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Fuse tap to MicroUSB?
    I bought a vent mount for my smartphone (music + google navigation + trapster ftw) and I have it on the vent right next to the driver's door (left of steering wheel). I love the setup, except that I have to run my DC adapter all the way from the cigarette lighter, over the steering wheel, into the phone. Is there a way to wire this so that I don't have to do that? Ideally, a fuse tap that runs into a micro-usb power head would be PERFECT, since the fuse box is right there. Google isn't helping me here.
    Anyone know how I could power my micro-usb phone when it's sitting to the left of the steering wheel without running cords across the cabin?
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Pull your vent out and fuse tap into something in the fuse box which is right below the vent. Or tap a cig adapter behind the dash an run the wires through the vent?
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Will that work fine without frying the phone for example? I'm VERY interested in this too. I have in-car navi already but also have a phone mount and use that for traffic updates many times
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I don't know how to do it, but it shouldn't fry the phone. Electrical devices only request so much power, and the line will supply that if possible, unless a fuse/breaker goes and stops flow altogether. The cigarette lighter has its own fuse that you could possibly tap into. I guess you'd just need to know which wires in a USB cable supplied power really to be able to do it.
    Sep 08 2009
    SE
    Quote Originally Posted by bigblue View Post
    Well, right, what I'm wondering is if anyone makes something that you can run directly from a fuse to a microUSB connector. I have no intentions of splicing it myself and ruining my phone, which will be the inevitable result.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    USB is 5V IIRC. I bet you can find a 12V -> 5V converter, or find someone who has electrical engineering experience and maybe make your own.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Aug 12 2009
    Dirty Jerz
    It is 5V. Wikipedia has the pin configuration and standard wire colors to correspond to the pins as well. http://en.wikipedia.org/wiki/USB
    Jul 27 2007
    Orange County, NY
    Was doing some googling and it sort of seems you'll need a 12v to 5v converter of some sort.
    Sep 08 2009
    SE
    Thanks, guys, I'll let you know what I find out. Right now I'm thinking it'll just be easier to mount an extra cigarette lighter plug to the left/underside of the steering wheel (near the vag-com port) because that can be accomplished with a $10 kit from walmart/radioshack. And Just use my existing cig lighter adapter.
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Ya like I said very easy, we sell them ad advance auto parts as well. I did that before for my radar detector since hardwiring it would blow it up without the cig adapter to drop the power down.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    my plan is to solder a few leads to my cig charger and connect the other end to the bottom of the cig lighter, then the whole thing can just sit behind the dash and i can still use my cig lighter for other devices.
    Jul 27 2007
    Orange County, NY
    Did anybody actually do this?
    Jul 27 2007
    Orange County, NY
    Anybody have more info?
    Sep 08 2009
    SE
    *bump* for coderedpl.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    I used one of these.
    I used a wire that I tapped for my dvd player in the fuse panel and soldered it to the tip. I then soldered a ground wire to the side terminal. It's all tucked behind the dash and it works like a champ to power my iphone.
    Mar 17 2008
    You can use simple circuit with voltage regulator and small radiator.
