Results 1 to 6 of 6
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    034 Valve Cover ** how to connect both hoses?
    I'm looking at the 034 valve cover (wrinkle coated, looks sexy): http://www.034motorsport.com/engine-...ing-p-757.html
    But I notice that it only has one port at the end whereas mine has TWO: one that goes to the elbow breather hose, and another, smaller one, that goes off of that same pipe/port to a short hose and then to a check valve. Anyone using this valve cover get the appropriate fittings to hook them both up?
    This picture shows what I mean:
    See the pipe perpendicular to the large pipe than runs to the elbow breather? Where the hell would that thing go on the 034 valve cover? They do offer like four variants of connections, but I can't make heads or tails of them.
    Sep 08 2009
    SE
    *bump*
    anyone using this valve cover?
    Aug 26 2005
    The tubing fitting with the smaller hose nipple attached, shown in your pic, is either a light press fit in the valve cover, or is a threaded connection. Therefore, remove the fitting from your valve cover and use in the 034 valve cover.
    Vorsprung durch Technik
    Sep 08 2009
    SE
    Sweet! thanks. I'd love to dress up my engine bay a bit. The valve cover is pretty gross every time I open the hood.
    May 03 2007
    Bay Area
    I was thinking about stopping by there and getting one....post pics please.
    Sep 08 2009
    SE
    Quote Originally Posted by audballz View Post
    I won't be able to get one for a couple months. I'm just thinking ahead. If I get it set up, I'll post pics. They have quite a few pics on their website though.
