This set of trim got installed over the weekend and I must say I'm pretty happy with how it turned out. It was made using the same type of fabric found on the OEM carbon atlas trim (8 harness satin weave or 8HS). It is the same weave I'm using to try and make matching vent and MMI pieces as well.
The only difference between these pieces and the OEM pieces is the tiny metal strip that runs along the top and the front side of the trim. We could do a set with those if we had a core set of trim that had them (say, from a wood set of trim).
I should have installed pictures of of the matching vent/MMI pieces installed sometime tomorrow evening.
