Originally Posted by
DoolBozorg
Hardwired the V1 remote display there...it's a great fit and can be covered with the little sliding door. Needed to get access from underneath/behind to run the cable.
Makes sense...but I put mine on top of the steering column in front of the center info display between the speedo & tach, with some Hook and Loop Superlock Fastener (the same stuff used to mount my E-Z Pass to my windshield) from Radioshack (
http://www.radioshack.com/product/in...ductId=2103345). The main reason being that I move the V1 between four different cars that I drive.
Mounted the splitter & power block on top of the fuse panel with some Ty-Raps, then just fished the wire for the remote display past the column boot and connected it there. The head unit is on my sunvisor, with the wire for that tucked under the door weatherstrip moulding that runs down the A-pillar past the fuse panel.
Please post some pics when you have it finished...I'd like to see what it looks like. Thanks.
