    Dec 05 2009
    New York
    headlights wobble when driving
    When driving at night behind someone, i noticed that if I am not on perfectly flat road, my headlights wobble a bit when i driver over any non-perfect surface. The aim of the lights get thrown around a bit. The lights are aimed fine when parked. Is this normal or does something need to be adjusted so they have less play? TIA
    Veteran Member Four Rings Bsix3.0's Avatar
    Feb 08 2009
    lots of bicycles..
    Aurora, Colo
    id first check all the screws holding in the headlights and make sure theyre all nice n tight..
    also check the bulb housing
    -Lee
    Veteran Member Three Rings Quattro_2.7tt's Avatar
    Jan 22 2009
    2007 S8, 2004 A6 4.2 6 MT swap, 2008 A6 S-line 3.2,
    Scottsdale, AZ
    plastic tab inside might have broke
    Current: 07 D3 S8 V10 - stock.
    04 C5 A6 4.2Q 6 MT swap and a lot more mods.
    08 C6 A6 3.2Q S-line - stock
    Sold:
    05 B6 S4 6MT
    01.5 B5 S4 6MT
    00 B5 S4 6MT x2
    99.5 B5 A4 1.8tq 5MT
    05 A6 3.2 Quattro
    Veteran Member Three Rings jesters22's Avatar
    Oct 14 2009
    new jersey
    on my friends a6 the projector housing came apart from the actual light housing and causes his lights to bounce up and down.. i think i got the names correct.. im not sure. but basicly the interior part that makes a square inside the light came out and just bounces inside the actual light.
    PARTING OUT A SILVER 2001.5 S4 PM ME FOR PARTS
    http://forums.vwvortex.com/showthrea...2#post83363922
    Dec 05 2009
    New York
    thanks for the help.. it got detached somehow at the bottom, not sure if it is the speed nut, cheese HD screw (wtf with these names), or both, i need to take the whole thing off to get a better look
