Results 1 to 9 of 9
    Senior Member Three Rings GeoergeA402's Avatar
    Mar 11 2009
    03 A4 1.8TQ Tip
    Midwest
    educate me on N75 valve
    I have a completly stock 1.8t motor, just curious as to what exactly the N75 valve does and if it is something worth getting/replacing on my stock setup.
    I did search and to no avail. I know sorry for such a noob question
    Any and all help would be greatly appreciated
    Thanks in advance.
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    The N75 in simple terms is a boost controller. Basically it has three ports and an electrical connection that allows the ECU to regulate the wastegate. 1 port is the inlet the other two are outlets one leading to the wastegate and one leading back to the intake. The ecu reads the boost pressure entering the N75 valve and opens the wastegate by sending allowing the pressure to flow through. The ecu will open and close the N75 many times to regulate boost.
    There are many other types of N75 valves on the market such as the "race valve". These are OEM valves found on other cars and act a little differently. Changin the N75 valve ill do little in the way of performance on a stock car. In fact if you mess with the N75 valve it will more than likely throw you into "limp mode" where you will not be able to boost over 5 psi. You can replace it with a manual or electric boost controller allowing you to set what psi you want to hit, but if you are not chipped this again will throw you into "limp mode". The best thing to do is if it is operating correctly leave it alone, and if you want more performance... a software flash is a good place to start.
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Mar 11 2009
    03 A4 1.8TQ Tip
    Midwest
    1+ is really all the further i plan on taking this car one cause its an auto and two I plan on having it my garage for many years to come. Plus in Omaha, NE there is no tunning shop for audi/vw. Plus I already have plans set in motion for my fast and fun car.
    Thanks for the knowledge and input!!!
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    As a performance mod, no, but you have an '03 like I do, and the parts are prone to failure. Based on reading the forum, I'd say 5-7 years and it's time to get a new one. A failing n75 causes all sorts of weird boost issues, so you may want to replace it as part of your preventative maintenance while you upgrade your performance. Food for thought.
    I just replaced mine last week.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    nothing wrong with upgrading a tiptronic, mine is holding solid as a rock as are many others.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by nein-reis View Post
    Slight correction the 3 inlets of the N75 are referenced to:
    1) Intake hose
    2) Turbo compressor housing
    3) Wastegate itself
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 11 2009
    03 A4 1.8TQ Tip
    Midwest
    I know that there is nothing wrong with upgrading the Tip however just makes it a lot harder with no local tuners.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by GeoergeA402 View Post
    Just curious as to what exactly the N75 valve does.
    Here ya go: Clicky click Click the link for a written explanation.
    Feb 01 2008
    SLC, Utah
    Quote Originally Posted by A4SoftWalker View Post
    1) Intake hose
    3) Wastegate itself
    Uh... thats what I wrote.
    -Tyler-
