Results 1 to 13 of 13
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    How to stiffen up Level 1 ride height so it doesn't ride like a boat?
    I'm looking for some input on how best to counter the softness of the level one AR setting.
    The car basically rides like a boat on the L1 height such that I drive almost exclusively at level 2. When cruising on the highway it goes down to level one automatically and then floats around corners and bobs up and down over bumps on L1.
    Is there anyway to stiffen it up, other than going the Arnott gen II route / Bilstein route? How much stiffer are the gen II airsprings matched to Bilstein shocks? I've already gone with H-sport sways which makes a huge difference with body roll, but it the suspension still needs tightened up quite a bit. Especially for level one.
    I'm guessing it's "just the way it is." For those that will ask, I have not done the 402 coding for L1, and all 4 airsprings are working fine.
    Thoughts?
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    I was thinking in my mind "402 Mod" but Then I read that you haven't done it. Possibly try it? If then you don't like it? start looking at other alternatives. For now try the inexpensive route.
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    mine isnt super tight feeling, more just stiff, with h-sports, 402(20mm), 605 relay delete, and 20" wheels. it kind of gives the illusion of better handling when each bump feels like a curb.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Sep 11 2009
    NE
    That's stock shocks. They seem to forget their role when at L1 or below (with 402 mod) and become bouncy/floaty. Once I replaced them with bilsteins from arnott (but still on OEM bags), the handling improved dramatically.
    It could be that if you replaced your shocks with new OEMs, the handling would also improve a lot. Your shocks are probably old just like mine were.
    Veteran Member Three Rings dfgu's Avatar
    Apr 22 2004
    I did the 402 mod 20f 18r, and when i'm in level 1, it does feel a bit like a boat, i keep it on level 2 most of the time. I also have the GEN2 Arnott bags and shocks...
    do you think it's the dampening of the shocks on level 1, that's causing the boat like feeling? It definitely feels stiffer on level 2.
    2011 S4, Prestige, Titanium, DSG - Grey
    Apr Stage 2+, Milltek dp/exhaust, Eurocode Headers, APR stage 2 Intake - Current
    2005.5 A4 Avant, Premium -Brilliant Black/ Matte Wrapped Blue
    Apr S03 kit, APR Catback, RAI downpipe/HFC, 034 Rear Sway,
    Snow Meth injection, 6spd - SOLD
    2002 Audi Allroad - Brilliant Black
    Stage 3 GT25 Vast Installed, EPL Tuned - SOLD
    2003 A4 1.8t - SOLD
    1999 A4 Avant K04 - SOLD
    1959 MGA 1600
    Chocolate Land, USA
    Some good comments here . . .
    From what I've read about the 402 "mod" is that it actually exacerbates the boat-like quality. Correct??
    julex: so your replacement of the OEM shocks with Bilsteins, while retaining the OEM airsprings, was a vast improvement . . . that's good to hear. Question: Looking at the install manual on Arnott; the OEM rear shocks and airspring have a hard tube between the two . . . the rear Bilstein shocks do not have this? How is this solved? A plug?
    dfgu: So you have the GenII airsprings and Bilstein shocks . . . and it still rides like a boat? What is the ride like compared to OEM and is there a handling improvement over the OEM system?
    I feel that if I have to take out all the bags to replace the shocks . . . it might be best to replace the whole system while it's all apart . . . the only limitation is the 2k price tag (even with 10% off).
    -Mark
    Got Vag-Com?
    Apr 22 2004
    Quote Originally Posted by Mark View Post
    With the 402 mod that I have, on level 1, it still rides like a boat, but on level 2, which is pretty much the stock level 1 i think, it rides nice and firm. A lot better than the oem setup. It handles the bumps a lot better, and corning is definitely improved.
    Level 1 just makes the car look really nice, but once i start driving, I raise it to level 2.
    With lifetime warranty, I think it's worth the shot to replace everything at once.
    2003 A4 1.8t - SOLD
    1959 MGA 1600
    Chocolate Land, USA
    Quote Originally Posted by dfgu View Post
    Good to hear . . . I've been thinking I'll probably go the GenII & Bilstein route, it's just a large hit to take at once on the wallet. I'm going to have to wait on that until after the holidays for sure. Lifetime warranty is a huge bonus.
    So the ride height of the GenII/Bilstein on L2 is comparable to OEM on L1? How much lower is the GenII/Bilstein on L1 compared to OEM L1? Ride height is a factor, but handling and ride quality are the most important considerations.
    -Mark
    Got Vag-Com?
    Apr 22 2004
    The GenII height is still the same as stock. i just did the 402 mod to lower the car even more than stock. Height is all dependent on what you set it as in the system. But with my 402mod at 20r18f, my level 2 is just about equal to what oem level 1 is.
    2003 A4 1.8t - SOLD
    1959 MGA 1600
    Chocolate Land, USA
    gotcha . . . makes sense.
    -Mark
    Got Vag-Com?
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    What tires are you running?
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Sep 11 2009
    NE
    it is definitely worth it.
    Sep 11 2009
    NE
    a plug. Design wise Audi overengineered the thing a little bit and incorporated a dynamic dampening system with a valve that lets some of the air inside of the shock to alter dampening. Allegedly this is for heavy loads only though... I personally see no difference from OEM to plugged Bilsteins, maybe because bilsteins are more aggressive to begin with. Something stock rears might be approaching but only when heavily loaded car is pressing on them.
