Results 1 to 7 of 7
    Established Member Two Rings Bvulic's Avatar
    Nov 04 2009
    Chicago
    Fuse box question?
    Ok i have a huge problem that has been bugging me for a very long time. Any help would be greatly appreciated. I have had my ABS and brake light turn on about 6 months ago. I sent my module in for a rebuild and installed it tonight, and the exact same problem persists. I know the module is the problem. So, I was extremely disappointed, and went for a drive. When I got home I decided to take a look at the fuse box to see if everything is ok with the ABS slot. So i look at the owners manual and it says slot 16 is the ABS fuse. 5 amps. I look, and there is no fuse in slot 16. So i found an extra fuse, and it wont sit flush in slot 16. By the looks of it, there isn't a terminal for the fuse. Is this normal? What gives? I am absolutely stumped. TIA.
    Nov 04 2009
    Chicago
    Thanks for the help guys.
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    heres a pic of my fuse panel for example
    Bentley manual says abs pump fuse is number 18 not 16
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Nov 04 2009
    Chicago
    Thank you that's all I needed. My owners manual says it's -16. I need to check out slot 18 tonight. What ampage is it
    Dec 06 2008
    2.0L 058
    LI
    10
    --> first start <--
    Senior Member Two Rings marioss4's Avatar
    Jan 18 2010
    bay area
    having the same problem which slot is 18
    Jun 30 2008
    Erie, Pennsylvania
    The map is embossed on the back of the fusebox door.
