Results 1 to 16 of 16
    Established Member Two Rings Baseballer's Avatar
    Aug 31 2007
    Audi
    Irvine/Seattle
    So what did I do to eff up my car now?
    Was doing a routine spark plug change on my 1.8 the other day. Now the car won't start, wtf. I was doing it quickly, so if there anything I could have messed up in my haste? I thought I hear a popping noise like when +/- wires touch, but that doesn't really make sense...
    "Home is not where you live but where they understand you" -Christian Morgenstern
    Senior Member Three Rings MLFHNTR's Avatar
    May 29 2010
    '04 Allroad, '02 GTI
    Daytona Beach
    more info on what the car is doing. When you try to start it does the starter turn? does the car just sit there and do nothing?
    2 Hooker Limit...
    Embry-Riddle European Car Club President
    Aug 31 2007
    Audi
    Irvine/Seattle
    It just cranks and cranks and cranks. And cranks...
    Aug 31 2007
    Audi
    Irvine/Seattle
    Just cranked the motor with a plug in the coilpack--no sparking
    Active Member Two Rings Racerx220's Avatar
    May 05 2010
    Philadelphia , PA
    did you hook the ground wire for the coils back up to the valve cover
    97 a4 1.8 , ASI intercooler hoses and turbo inlet tube , 710n dv , vdo boost gauge ,
    Veteran Member Three Rings T0mat3's Avatar
    Oct 05 2008
    St-Anne des Lacs Canada.
    Did you gap them right?
    Active Member Two Rings spunkz's Avatar
    Oct 09 2009
    Audi
    New York
    check realay under ecu box sometime they get wet n effed up happened to mine
    Jun 30 2008
    Erie, Pennsylvania
    I'm going hazard a guess that the rustling of the [cracked and heat-damaged] coil pack harness shorted it out.
    Check Fuse 32 (if it's an AEB engine - 97-99.5)
    Check Fuse 29 (if it's an ATW or AWM engine - 00-01.5)
    If one of those is blown you will need to repair the short in the coil pack harness, then replace the fuse.
    May 29 2010
    Daytona Beach
    It is most likely as stated above. If they were just gaped wrong the car might still right; all be it, poorly.
    2 Hooker Limit...
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    yeah make sure you hooked up the ground wire on the valve cover, make sure you gap the plugs because 99% of the time they are never pre-gapped
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Aug 31 2007
    Audi
    Irvine/Seattle
    Thanks for the help everybody. There is only one ground wire right?
    Feb 06 2006
    '01 A4 1.8T, '01 Audi S4 Avant, '15 Dmax High Country, '01 Spec Miata #13
    Suffield, CT
    There is like two wires heading to the one location of the ground wire. Why did you take it off though? I can do my change without touching it.
    2001 A4 1.8t | Under Construction
    2001 S4 Avant Hybrid K04, EPL Tuned.
    2014 Touareg TDI (Hers)
    2015 Chevy 2500HD Dmax High Country
    2001 Mazda Miata Spec'd Track Whore #13
    Feb 06 2006
    Suffield, CT
    Things to check:
    1)Ground Wire
    2)Coilpacks are all plugged in correctly
    3)Sparkplugs are gapped to .028"
    4)Fuses
    Aug 31 2007
    Audi
    Irvine/Seattle
    Lol #27 fuse was out. Thanks everybody. Hey, these plugs don't even look that bad do they?
    http://picasaweb.google.com/DerekBon...88433260388914
    Feb 06 2006
    Suffield, CT
    Still look decent. Are those coppers?
    They do wear out more rapidly than say platinums
    Aug 31 2007
    Audi
    Irvine/Seattle
    Iridium. One of the ground electrodes was worn on the side, rounded off, maybe that was the issue.
