Results 1 to 4 of 4
    Senior Member Two Rings 1SICKAUDI's Avatar
    Feb 03 2007
    Michigan
    Low Beam Light Replacement
    Hello All,
    Today one of my low beams stopped working. If I do not have projectors in my headlights, what type of bulb do I need to order? I am currently looking at Osram Nightbreaker 55w for this replacement, as I've had a good experience with them on my Lexus. Moreover, how can the lights be replaced? The lights didn't seem very accessible.
    Thank You.
    EDIT: The low beams are H7's. How can the lights in the passenger's side be accessed?
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Should be able to remove the snorkel leading to the aircleaner and everything would be accessible from there; don't have halogen headlights so don't know how much room is actually behind the housing to replace H7 bulbs.
    Current:
    2017 B9 A4 Technik 2.0T 6 spd manual S-Line
    2008 B7 A4 Avant 2.0T 6MTQS S-Line
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Veteran Member Four Rings ryanworth's Avatar
    Nov 16 2009
    Los Angeles, CA
    It's quite simple. Remove the snorkel for the air intake. Then remove the rear cap to the halogen housing. You will see a metal clip holding the bulb into the socket. Squeeze the clip and slid it off (should swing upwards). You can then pull the bulb out, unplug, and replace.
    Hope that helps.
    Ford Focus - 2.0 Gray Four Banger Bad Ass Hatchback - Current
    B7 S4 - 6MT Dolphin Gray Avant - Old
    B7 A4 - 2.0T 6MT Quattro Brilliant Black Titanium S-Line - Old
    -Ryan
    F.T.W.L.T.B.D.W.I.C.T.W
    Feb 03 2007
    Michigan
    Thanks for the instructions guys.
