Results 1 to 10 of 10
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    What the purpose of having a breather on a catch can?
    just wondering. going to make a cheap one and want to know if its better or doesnt matter if its there. i would imagine youd be able to smell it, right. if thats the case just vent it to atmosphere, with a filter. id rather not smell it so...
    pros. vs. cons.
    Go.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Well first search cause this has been covered many times. But, I would say you should vent back into your TIP from the output of the catch can. And, I would be interested to see how and what you would make one, so if you do, post it up.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Veteran Member Four Rings jmw241's Avatar
    Feb 23 2009
    Cranston RI
    Venting to atmosphere will leave you with a strong smell of oil all the time, mostly when your at a stop and the car is running.
    The idea of the catch can routed back to the tip is to create a vacuum source to depressurize a crankcase, a good idea in turbo motors.
    Just get a catch can if your gonna do it, unless it's a track car.
    -Justin
    Current Cars: 07 Sprint Blue RS4 Cab,
    Old Cars: | EURODYNE Maestro | GTX-3071| B6 A4, Brilliant Black b6 S4, Phantom Black B7 A4
    07 Sprint Blue DTM S4, 12 Candy White Golf TDI
    Jan 08 2010
    CT Shoreline
    thanks for the info. no not a track car, spirited daily driver!
    a catch can is very simple in design and can be made hundreds of ways, cheap to pricy. seach cause its been covered many times <**-poke!
    i understand why not to vent to atmosphere, and why to keep it sealed. the question should have been worded more clearly.
    theyre are "catch cans" with lines going in and out, with a drain,(like a conventional catch can) but also with a small filter on top. what is the purpose of that fiter/breather.
    i have searched but did not come up with an answer.
    this is just the first one i found to show you, not one im going to buy.
    http://cgi.ebay.com/UNIVERSAL-OIL-CA...item4cf1bedc01
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    The 42 draft designs stealth catch can looks nice, I've been thinking of picking one up once my car is out of the shop
    Aug 26 2005
    Quote Originally Posted by MikeWire View Post
    2nd on venting into the TIP.
    Vorsprung durch Technik
    Feb 23 2009
    Cranston RI
    How I did it :
    -Justin
    Aug 26 2005
    Quote Originally Posted by heywier427 View Post
    The small filter is to insure the pressure inside of the catch can is always the same as the ambient air pressure. However, provided the catch can is not a dead end in the vent line, there is no technical reason that this is required. Depending on how the catch can is installed, the filter will reduce the capture and retention of oily aerosols and water in the catch can. The best and most effective catch can setups are sealed ventilation, not connected to the outside air.
    Mar 27 2008
    Denver
    That's clean^ I need to figure out how to route mine. It looks like shit now that I put the stock air box back in. I don't really mind the smell at lights though lol, at least I know what it is.
    Jan 08 2010
    CT Shoreline
    thank you diagnosticator!
    i will be going with a sealed can.
    im either going to make a small one thats to be drained every oil change, or, i found this, and think i like it!
    http://cgi.ebay.com/ebaymotors/Go-Ka...Q5fCarQ5fParts
    ive asked the seller for better photos, just waiting for the response. but better photos or not, im going to try it anyway.
    thanks everyone.
