Results 1 to 17 of 17
    Apr 27 2010
    OR
    Fog lights on without headlights
    How do you turn on your fogs without turning your headlights first?
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Do a search for the independant fog light mod.
    It involves modifying the fog light relay. GL
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Established Member Two Rings xRAYx's Avatar
    May 30 2010
    Chanhassen/MN
    Kinda of a pain in the ass but worth it.
    Jul 14 2009
    phoenix md
    +2 i somehow made it so my rear fog light doesnt work though in the process :/
    good luck
    Veteran Member Three Rings Robb12's Avatar
    Aug 04 2008
    Orange County
    Here's the DIY I used. It's not too hard, the hardest part for me was getting the relay box out because it's such a tight fit.
    http://www.audiforums.com/forum/showthread.php?t=90540
    Current - 2008 A4 Avant 2.0T Quattro, S-Line, Titanium, 6-Speed Manual
    Sold - 2005.5 A4 2.0TQM - Not Forgotten
    RIP 2000 A4 1.8TQM k04
    Jun 30 2008
    Erie, Pennsylvania
    Independent fog modification is vastly different for 96-99 cars than for 99.5-2001.5 cars. Namely, the cars prior to 99.5 (aka "prefacelift") don't even have the fog lamp module.
    Basically, if your door handles are flat and square, you've got more work to do. Just FYI
    Established Member Two Rings dtmeurosport's Avatar
    May 03 2010
    earth
    Quote Originally Posted by Robb12 View Post
    +1 this is the one I used as well. that relay box was a PITA to get out. totally worth it for me though!
    Senior Member Three Rings Insomniac's Avatar
    Jun 02 2008
    Hershey
    Just be careful with the amount of solder you use. It's a fairly small work area.
    free earl
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Has anyone made a DIY for the pre-facelifts?
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Whats the point for the pre facelift?
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by stevejones19 View Post
    pretty sure no one has wasted there time, they use a completely different system compared to the face-lift style, and just running the fogs in the 2-peice housings looks really funky, i wired them up for a sec and it didnt look good at all, this is when you upgrade to one piece headlights and fog lights
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Jun 30 2008
    Erie, Pennsylvania
    Pre-facelift wouldn't be too bad. Full independent operation (no high-beam self-cancel) would be the easiest to implement. You just need to pull fuse 36 (power to the fog buttons) then run a fused wire from the [fuse socket's] load pin to the 75x terminal. That way the fog buttons get power with the key (rather than with low-beams). Then you just replace the fog lamp relay with a heavy jumper wire and [KA-POW!!] independent fogs.
    Keeping the high-beam self cancel would require keeping the fog lamp relay, and changing it's low-beam input signal to a 75x signal. Not hard, just not as easy as jumping past the relay.
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Quote Originally Posted by SantorianA4 View Post
    Because i'm trying to get a pair of the s5 style lights and i wanna put the l.e.d.'s on by themselves.
    Oct 03 2008
    what garage?
    Pittsburgh
    So set them as your DRL's
    16' Silverado HD
    Nov 30 2008
    06 Wrx
    Olympia, WA
    No DRL's on my car. Have to turn them on manually. And up once on the lever is just parking lights, then up the second time is everything on. I don't want the parking lights and the fogs to be on.
    Oct 03 2008
    what garage?
    Pittsburgh
    Well you dont have fogs right?
    What i did is used the wire from my amber parking lights to run my LED's
    So one click up LED's, 2 clicks up Lights / LED's
    I hate the way the amber side lights looked anyways. Turn signals still blink amber fine.
    and they wont go out with your high beams
    16' Silverado HD
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Well that sounds a bit more logical that way. lol.
    I actually like that way. I've just ran through the fog mod in my head since it seemed easiest, but things usually come together in my head more when i actually have the wires in my hand and figure out what would work best. Thanks for the idea
    And i do have fogs, they're built into the headlight. They really don't do a WHOLE lot, but it's a little light in the low areas.
