Results 1 to 16 of 16
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Dentist visit... Always at the perfect time!
    For the past few weeks, I've been chasing the ghosts of owners past. Finding neglected boost leaks, replacing an axle, replacing brakes with more hot spots than the surface of the sun, and finally trying to identify my Frankentune (which I still have been unsuccessful with).
    When almost as if on cue, the dentist drill symphony begins as I drive home from work last night. First thoughts, "why do I own this car again?", "how long do I think I can drive on my dying friends?", followed by a long line of explicits...
    Of course, it's at the worst time ever. Just started a new job and school is nuts. Great. Oh well, c'est la vie... Might as well get some other stuff done while I'm in there.
    I'm not familiar with the lifespan of whining turbos, but I'm looking into prices right now and wanted some advice.
    I'm looking at:
    RPK04's w/install kit (ECS) for $1529.00 OR BW K03's from who knows where for who knows how much ??
    RS4 clutch (ECS) for $449.95 OR Stage 2 Clutch Kit (AWE Tuning) for $649.00
    TB Ultimate Plus Kit (ECS) for $279.95 (I have the cam lock tool already)
    Autobahn88 eBay Hose Kit for $110.00
    My main question is, should I just stick with BW K03's? I have plans down the road and it would be nice to get a jump with K04's, but I can't do too much with supporting mods until after winter...
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    My have been whining forever, i only get on the boost when i need to. Go with K04s.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Account Terminated Four Rings
    Sep 18 2009
    Andrews
    Look up Frankenturbos. Actually looks like a good product. Talk to DXC he is testing them out.
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    Just get BW KO4's now and do the supporting mods later when you have the money. I sort of feel like if your gonna pull the motor, you should make it worth your while. You can do a clutch later as you don't need to pull the motor for a clutch...although it is easier once it's out. That's my plan for when I have to do turbos. Being a poor college kid means I'm expecting to not have any extra money for when the stickers blow.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Veteran Member Three Rings Quattro_2.7tt's Avatar
    Jan 22 2009
    2007 S8, 2004 A6 4.2 6 MT swap, 2008 A6 S-line 3.2,
    Scottsdale, AZ
    My turbos are whining under full load but I know theres a vacuum leak at the fpr line. Hopefully these turbos last a bit longer. Im at 144k with originals.
    Current: 07 D3 S8 V10 - stock.
    04 C5 A6 4.2Q 6 MT swap and a lot more mods.
    08 C6 A6 3.2Q S-line - stock
    Sold:
    05 B6 S4 6MT
    01.5 B5 S4 6MT
    00 B5 S4 6MT x2
    99.5 B5 A4 1.8tq 5MT
    05 A6 3.2 Quattro
    Active Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    save your cash while you drive it they can whine and last a long time.when they do go if they do at all anytime soon go with ko4s or tial whatever you want and can afford.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    RS4 clutch is a waste of money and so is new K03's.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Fry Sauce, UT
    Quote Originally Posted by RolledMySTi View Post
    I haven't even checked prices for K03's, it just seems like a retarded idea to replace with the same thing once you're in there. Unless it's some gigantic/magical reduction in price. Just had to keep it an option.
    As far as the clutch goes, what's the next best thing to the RS4? From looking around there doesn't seem to be too much in the same price bracket that is comparable... The car has 82k and I'm going to eventually need more holding power, but nothing insane.
    - Steve
    NKAWTG
    Veteran Member Four Rings 99ebpsi24's Avatar
    May 04 2008
    10 S4 prestige, 12 A4 S-Line, 00 Stg3+ S4, 74 VW Thing, 74 Z28 camaro (32k original miles) 74 Z28 Ca
    Cincinnati
    x2...start saving for k04's or bigger. You can add fueling and stuff later, it just doesn't make sense to pull the motor to put the same turbos back in. If you keep it out of boost now you should be alright for a while.
    Current:
    19’ Ara Blue RS3 UniFlex stg1+, stg2 tcu, midpipes & IE intake
    21’ VW Atlas SEL Prem. R-Line
    15’ Sepang Blue S3 Prestige
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    huge 2nd. its just an S4 disc with a different pressure plate. look at the clutch options from VAST, they seems pretty reasonable on price.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Fry Sauce, UT
    Thanks for all the advice so far. I've got one last question, I've noticed over the past few days that the turbos are the loudest right in the morning on cold startup. As the day goes on, the car gets to oper temp, etc. the turbos quiet down substantially. It's almost to the point of not hearing any drill noise at all...
    Could this be a sign of a crapped up feed line? Or is it just the fact that once the turbos heat up, they're bound to quiet down...
    - Steve
    NKAWTG
    Jan 15 2009
    pennsylvania
    dont think so my turbo would be alot louder on startup too.once they warm up they quiet down.just drive it until its a problem thats my advice.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    spend the extra cash for bw k04s and just run a stage 3- set up. Im a broke college student too and thats the route I took. It's nice not worrying about your turbos blowing or leaking like some RPs do
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp Package
    Junior Member One Ring
    Jun 20 2005
    Hoboken, NJ
    Don't do K03s. They're just going to blow again.
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    I hope you haven't limited your search to ECS
    WTB (1) OEM A8 Flat Five 18x8.5 et45
    WTB Black 6spd Shift Surround
    Fry Sauce, UT
    Quote Originally Posted by phila_dot View Post
    I haven't, just haven't had the time to really dive into prices from other distributors. Any words of wisdom that could potentially reduce that search time would be be greatly appreciated though!
    Right now it's looking like either BW K04's or the frankenturbo stuff (still waiting on some feedback along with everyone else on AZ for the FT's though...)
    - Steve
    NKAWTG
