Results 1 to 10 of 10
    Feb 12 2004
    '01 RS4(B5)2.7T, '07 A3 2.0TDi, '12 Q5 2.0T, '13 Mk6 GTI
    Q.C., Philippines
    9.5x19; et30 fit on B8 S4?
    Hi has anyone tried mounting a 9.5x19; et 30 in their B8 S4?
    Senior Member Two Rings dkky996's Avatar
    Jul 04 2010
    2008 Porsche RS60 Spyder, 2008 Mercedes Benz CLS550
    Louisville
    Quote Originally Posted by tigasTT View Post
    Et 30 with 9.5...There is no way that's going to work. I have 19x9.5 with et41 and its a tight fit.
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    255s won't fit...this is certain. 235s will, but the stretch looks off to me. 9.5s on the car needs to be et 38 to 46 I'd say. and then the tire would also have to match those ets.
    I love to see the 9.5s et41s 255s. have a picture? must look great.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Senior Member Three Rings legbend's Avatar
    Sep 06 2009
    Chi
    How does Stasis fit a 275 tire on their wheels? ie, what's the width/offset?
    2010 S4 - SOLD
    Prestige, Drive Assist, Sport Diff
    Exterior | OEM Black Optics Grille
    Engine | Stratmosphere Intake, Stasis ECU
    Sep 03 2009
    They use 9" rims and large offset numbers. 20 or 19 by 9" et48. Going to 9.5" makes them closer to the suspension on the front, so et48 on 9.5 would rub...instead one must do a wee bit of fender work and use et 45 or 46 with 275s. (plus it has to be a somewhat skinny 275 brand....a fatty would rub)
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Jul 04 2010
    Louisville
    Quote Originally Posted by L0U View Post
    Hey Lou, I decided to go with 19x9.5 et 41 after reading your advice on your wheel+tire thread. Thanks for the info, I think it turned out pretty nice! I figured I couldn't go wrong following info from a fellow Duc rider.
    Hey Tigas TT, sorry to hijack your thread.
    Front:
    Rear w/5mm spacer:
    Additional pics:
    The car will be slightly dropped sometime this week...
    Sep 03 2009
    Sweet. I wondered what that might turn out like. Onced dropped it should be bang on. (if you turn the wheel at the dront all the way to one side to reach the back...any idea how many mm's between the rim and suspension? I am guessing 7mm?, but the measurement would aid in sticking 275s on 9.5 with the right et.)
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Jul 04 2010
    Louisville
    I can certainly measure it for you this afternoon. Are you asking about the space between the suspension arm and the back side of the rim once the wheel is turned all the way?
    Sep 03 2009
    yes, you turn the wheel to make space to get back there. the clearance stays the same.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Jul 04 2010
    Louisville
    Even with the wheel turned all the way, there wasn't much room to use any measuring device directly. I used a set of shim stacks to measure the clearance between the wheel and the suspension arm and I used a micrometer to measure the shims. The clearance was about 12mm measuring directly parallel from the wheel to the suspension arm.
