Originally Posted by
salts
Haha shit! Looks good! I guess im going to have to get my tuning wrapped up rather soon!
If the crank does not turn with a wrench, something is either bound up in the bottom end or the valve train. Simple as that. If its the valve train it will feel springy due to belt stretch. If the bottom end were locked up or say something was in a cylinder keeping it from rotating it will be locked up tighter than a drum :/ If it rotated before im sure its ok. I think you have another issue here. If you try rotating the motor over with a wrench, it should be difficult (due to compression) then get easy, then difficult, then easy etc. Either the starter is not working or you have some other issue.
I know this sounds retarded, but double check everything including your brain. I didn't drive a stick for a year while i was building mine and my car wouldn't start because i was so nervous about starting it i forgot to push the clutch pedal in and my boost gauge was covering the big red screen that says " push clutch to start engine". Anyways. This could be something very simple. Check all wires to starter and grounds. Also, before you panic, get under the dash and make sure that the "fully disengaged" clutch pedal swtich is engaging. Mine somehow got bent out of the way and the car would not start with the clutch pedal depressed. Its a small (maybe 1/2" by 1/2" ) black sensor with a small plunger that sticks out of it that will hit toward the upper top of the clutch pedal arm. Its hard to see. You really have to get up in there to look at it.
Those are just a few things that i would check before getting really upset. Check those out and go from there.
Thanks man, these are things I need to look into for my process of elimination.
salts
Everything is done. Finished Breaking the engine in last week. Ready to tune. Waiting on my laptop to get fixed so that I can log and load tunes. Hopefully start revisions in a few weeks.
Congrats man, I expect big things from that setup. Keep us posted on the results
Dubluv11
it should be hard to turn, but not TOO hard... if it doesnt turn at all thats bad news... that means over time your pistons dried up and corroded and siezed to your cylinder walls and tozoM8 totally beat me to the throttle adaptation idea.. did you try that yet? low voltage at terminal 30 could be a bad battery connector... clean the battery posts up with an sos pad and slap the terminals back on there nice and snug. go from there and let us know what happens... good luck bud!
ps... i'd like to have surprise butt secks with your motor
hahaha, no sex with my motor, only lube it gets is motor oil. With regards to turning the motor by hand. Prior to installing the heads, in order to line up the crank for TDC, I had rotated the crank multiple times - turned really easily, cylinder walls were freshly honed with new piston rings etc so everything looked clean. I don't think it would have seized that quickly. But with the heads on and the timing belt on, it became difficult to turn. I didn't try to turn hard though.
Could something have happened in between putting the heads on the block, so much that it would make it that difficult. Or is that simply the compression resistance?
Just installed a legit 409 version of VAG, I'm literally sitting in my car about to do this throttle adaptation.
