Results 1 to 11 of 11
    May 05 2009
    Cupertino
    Vagcom Fault code need help~
    Hi guys, my CEL just came on last night and ran it through my Vagcom cable found the following error:
    Address 01: Engine (****-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 D HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H12 0002
    Revision: E1H12-**
    Coding: 0104010A190F0160
    Shop #: WSC 80182 025 419494
    ASAM Dataset: EV_ECM20TFS8K2907115D A01002
    ROD: EV_ECM20TFS8K2907115D.rod
    VCID: 3064FC75DA51
    1 Fault Found:
    2811 - Fuel Trim; Bank 1: System Too Lean
    P0171 00 [237] - Open Circuit
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 17222 km
    Date: 2010.09.25
    Time: 13:30:45
    Readiness: 0000 0000
    My tank is half full with shell premium and I am using Motul 5w-40 X-cess.
    Just checked under the hood, the only thing I can see out of ordinary is my Engine Coolant (the G2 thing) is below minium
    thanks in advance!
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    I am not with my laptop aka: VAGtop now, I will look at the label 06H-907-115-CAB.clb tonight and see if I can find out what it is for you.
    Jul 04 2009
    by the look of it, it looks like a fuel/timing issue here on hand.
    May 05 2009
    Cupertino
    hmmm do you think I would need to bring this in to the dealer to have them check it out? or could it be an easy fix?
    Aug 10 2009
    i had my fuel pump fail on me already.
    Jul 04 2009
    ^^really? how many miles do you have? and is it a 1.8t pump or 2.0t pump?
    Aug 10 2009
    2010 1.8t model. Had about 10k km.
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
    May 05 2009
    Cupertino
    Thanks for that, i erased the fault code and it have not came back on again, should i be worried? Because i am on a road trip right now so it will be hard for me to waste a couple days at the dealer
    May 05 2009
    Cupertino
    UPDATE:
    The fault code came back on again last week and I went into the dealer , replaced prudge valve / pipe assembly and was fine again.
    Today it came on again and had something new
    Revision: E1H12-**
    VCID: 3064FC75DA51
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 17849 km
    Date: 2010.10.15
    Time: 12:38:29
    4166 - Manifold Pressure / Boost Sensor (G31): Signal too High
    P0238 00 [032] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 17783 km
    Date: 2010.10.12
    Time: 13:41:42
    Readiness: 0010 0000
    Could it be APR code related ? because last time the code went away when I switched back to Stock mode and drove for about 20 mile to the dealer.
    or maybe my new installed Eurocode HFIC?
    because I don't really want to reinstall the OEM intercooler pipe just to get back to the dealer...
    2015 SQ5 :034 Trans Insert, 034 RSB, 034 X-Brace, H&R-1, Photosync front, Xpel front, OptiCoat, Windsea Sunshade, EPL....$$$$$
    SOLD : B8 A4 2.0T Quattro / Huper Optik 50% / Eurocode FMIC /Eurocode USS system/ APR Quad Tip Turboback / APR K04
    May 05 2009
    Cupertino
    Apparently I didn't tighten the bottom of the HFIC and it was sucking air, causing the CEL. The dealership didn't charge me for it for tightening it, hopefully it won't come on again .
