Results 1 to 9 of 9
    Senior Member Two Rings JCN83's Avatar
    Oct 14 2009
    Dash / Cluster Question...
    Tried searching but can't seem to find any info on this...
    When I turn my headlights on the green headlight indicator on the dash comes on...but in daylight, it's pretty hard to see. even at dark, it doesn't look as bright as it should. pretty dim and I'm worried that it's going to go out completely.
    does anyone have experience with this? i've never removed the dash or cluster before...are there light bulbs back there that can be replaced?
    TIA
    2023 RS6 Avant
    Senior Member Three Rings hihosilver's Avatar
    Mar 09 2008
    2003 a4 1.8t
    Boston, MA.
    speaking solely from an electronic standpoint (i'm an electronic engineer), bulbs are more of a dead or alive item. meaning they either work or they dont. i think your problem lies elsewhere. perhaps you have something in the car thats drawing some of the current from your cluster. do you have an aftermarket stereo or any other electrical modifications like a boost guage or hardwired gps or radar detector?
    I'd try using someone elses juice(via jumper cables) to see if it makes the bulb get brighter..
    2003 A4 1.8TQM
    USP Front valance / S4 Rear valance / B5S4HP2's / F&R Drilled n Slotted / F&R ECS SS Lines / F&R EBC RedStuff / Motul RBF 660 / ECS RA4 Stage II Clutch w/ Lightweight Steel Flywheel / ABD Cold Air Intake / Optima Red Top / ECS Coil Holddowns / DDM Tuning 55W8K HID Low, DDM 35W6K HID fogs / B7 RS4 Reps / ABT Sportsline Pedals , Dead Pedal / LLTEK Injection Molded Mats / Hardwired GPS / PODI Boost Gauge
    Oct 14 2009
    Thanks for the feedback...
    Yes - I have a boost gauge, a hardwired V1, and an aftermarket amplifier amp hooked up. I'll try disconnecting one (or more) and see what happens...
    2023 RS6 Avant
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    mine does this too, the headlight indicator appears faintly lit, except for my car is mostly stock. i.e. no aftermarket electrical parts.
    i remember somewhere that this may be a mod through vag-com or perhaps just a faulty cluster.
    I may have read that there is some vag-com coding that applies to the appearance/brightness of the indicaor, but im not really sure.
    i am interested in the solution to this since ive always found it odd that it is dim.
    what does everyone else's look like? bright green? pale?
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    Just got home about 20 minutes ago, i didnt notice that there was a light on, besides the CEL of course. Next time i drive im gonna look out for it
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Veteran Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    stupid question... did you try turning the dimmer knob on the cluster? is it possible that you just have your dimmer way down? lol
    Oct 14 2009
    Quote Originally Posted by skinnytirez View Post
    Yeah...unfortunately that doesn't do the trick. The rest of the indicator type lights in the dash come on very bright. It's just the headlight indicator...
    2023 RS6 Avant
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    So your headlight indicator is bright at night and dim during the day? may i ask why you are running your lights during the daytime?
    I'm pretty sure there is a light sensor built into the top of the dash (somewhere near the defrost vents) that detects ambient light and during the day it will detect the sun and dim the light automatically...
    Oct 14 2009
    No - it's always dull. Period. If I turn the lights on as it's first getting dark out...late afternoon/ early evening/ dusk or whatever...i can barely see the light. Practically nothing. As it gets pitch black, I can make it out - but still very, very faint.
    2023 RS6 Avant
