Results 1 to 7 of 7
    Senior Member Two Rings collins123420's Avatar
    Jul 07 2008
    '04 A4 1.8tcvt Moro
    Meguiers Compound?! (search wont work on phone!)
    Does anyone have any experience with Meguiers compound?! I havent washed or waxed my car in a whiiiile lol, she's been very neglected unfortunately :( and I have some pretty bad marks and scratches, just wondering if this compound does wonders (like ive heard) or not?!
    Thanks in advance!
    *SP*
    Veteran Member Three Rings dino's Avatar
    May 24 2004
    2003 Audi A4 1.8T 5MTQ, 2015 Audi Q7 Sline 3.0TQ
    Which Meguiar's Compound are you referring to? There's several.
    ~> dino
    2003 A4 1.8T 5MTQ - Brilliant Black on Ebony
    | Bose | Cold | Premium | Sport | Xenon |
    | Visor | A4 Rubber Mats | Tint | Aero Kit | Ross-Tech KEY-USB | V1 | Podi | Euro Knob |
    | APR K04/Snub | GFB Hybrid | TT225 Injectors | AMS SS | RaceTec FMIC | Hayden PSC |
    | B5 S4 Front Brakes | Hawk HPS | ECS Lines | Motul RBF 600 | RS4 RSB | PSI TP |
    Items for Sale
    Mar 27 2005
    The Cold North
    Which one are you refering to? I provided a list to help you pick.
    ULTRA CUT COMPOUND
    Item Number: M10501 1 gal. (3726 ml)
    Exclusive, super-micro abrasive technology FEATURES: • Ultra-fast cutting removes 1200 grit or finer sanding marks • Super-micro abrasives leave best in class finish • Also great for removing scratches, defects, acid rain and severe swirls/holograms
    ULTRA CUT COMPOUND
    Item Number: M10532 32 oz.
    ULTRA FINISHING POLISH
    Item Number: M20501 1gal (3726ml)
    * Permanently removes swirls and light defects from all paints.
    * Produces deep reflections and high gloss
    * Smooth-glide buffing feel and fast wipe-off
    * Environmentally responsible, Safe, VOC compliant formula
    Item Number: M20532 32oz (946ml)
    SPEED CUT™ COMPOUND
    Item Number: M9501 1 gal. (3726 ml)
    Fast cutting, traditional-feel compound with modern technology FEATURES: • Fast removal of 1200 grit sanding marks • Great for removing scratches, acid rain, severe swirls/holograms • User-friendly, crystalline silica free, VOC compliant formula
    SPEED CUT™ COMPOUND
    Item Number: M9532 32 oz.
    MEDIUM-CUT CLEANER
    Item Number: M0116 16 oz. (473 ml)
    Medium-Cut Cleaner is a moderately abrasive cleaner that removes medium defects, including swirls, water spots and water sanding marks. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scratching.
    MEDIUM-CUT CLEANER
    Item Number: M0164 64 oz. (1893 ml)
    FINE-CUT CLEANER
    Item Number: M0216 16 oz. (473 ml)
    Fine-Cut Cleaner is a mildly abrasive cleaner that removes fine surface defects including light oxidation, stains, scratches, swirls and fresh water spots. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scratching.
    HEAVY-CUT CLEANER
    Item Number: M0416 16 oz. (473 ml)
    Heavy-Cut Cleaner removes deep swirls, scratches, severe oxidation, alkaline and acid rain etching. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scratching.
    COMPOUND POWER CLEANER
    Item Number: M8401 1 gal. (3726 ml)
    Compound Power Cleaner contains aggressive abrasives to boost cleaning power and efficiency. Specially formulated for fast, safe cleaning. Quickly removes Meguiar’s® Unigrit® 1200 grit sanding marks. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scouring.
    Item Number: M8432 32 oz. (946 ml)
    DIAMOND CUT COMPOUND®
    Item Number: M8501 1 gal. (3726 ml)
    Diamond Cut Compound® 2.0 is a super fast, low swirl compound. It’s the answer for high solids paint; cuts super fast with minimal swirls. Successfully tested in high solids production shops. Low-dusting, low splatter formula.
    Item Number: M8532 32 oz. (946 ml)
    SWIRL REMOVER
    Item Number: M0901 1 gal. (3726 ml)
    Swirl Remover 2.0 is a deep gloss cleaner/polish. It removes fine scratches and swirl marks, while providing a dark, dramatic shine. Formulated to reduce splatter and make application and wipe-down easier.
    SWIRL REMOVER
    Item Number: M0916 16 oz. (473 ml)
    SPEED GLAZE
    Item Number: M8001 1 gal. (3726 ml)
    Speed Glaze provides paint shop safe protection. Removes light to moderate swirls, oxidation and paint defects. Restores a glistening “new paint” shine. Versatile – can be used with a rotary buffer (wool or foam pad), D/A polisher, orbital or by hand. Easy, low dusting wipe-off.
    SPEED GLAZE
    Item Number: M8032 32 oz. (946 ml)
    BODY SHOP PROFESSIONAL SWIRL FREE POLISH
    Item Number: M8201 1 gal. (3726 ml)
    Swirl Free Polish is a high performance polish that eliminates swirl marks fast. Specially blended polish with cleaning power removes fine scratches. Smooth, fast application and easy wipe-off. Restores a glistening “new paint” shine.
    Item Number: M8232 32 oz. (946 ml)
    BODY SHOP PROFESSIONAL DUAL ACTION CLEANER/POLISH
    Item Number: M8301 1 gal. (3726 ml)
    Dual Action Cleaner/Polish removes light to medium contamination, blemishes and oxidation that Swirl Free Polish will not. Combines the perfect amount of abrasive cleaner and pure, rich polish to produce a customer pleasing deep gloss shine. Safe, Buffered Abrasive™ cleaning removes defects without marring the finish.
    Item Number: M8332 32 oz. (946 ml)
    MACHINE GLAZE
    Item Number: M0316 16 oz. (473 ml)
    Machine Glaze outshines all other machine applied polishes, glazes , waxes and sealants. Penetrating nutrients revitalize all paint finishes. Buffing residue wipes off easily. Restores original brilliance and clarity. Safe and effective on fiberglass, plastic and paint.
    MACHINE GLAZE
    Item Number: M0364 64 oz. (1893 ml)
    NEW CAR GLAZE
    Item Number: M0516 16 oz. (473 ml)
    New Car Glaze produces a high gloss with minimum effort. Provides rich nutrients to restore paint's shine. Ideal for humid conditions. Safe and effect on fiberglass, plastic and paint.
    SHOW CAR GLAZE
    Item Number: M0716 16 oz. (473 ml)
    Show Car Glaze outshines all other hand applied polishes, glazes, waxes and sealants. Restores a dazzling, deep, wet shine. Show Car Glaze does not dry white and is safe and effective on all paint finishes.
    SHOW CAR GLAZE
    Item Number: M0764 64 oz. (1893 ml)
    CLEANER/WAX
    Item Number: M0616 16 oz. (473 ml)
    Clear/Wax's one-step application cleans, polishes and protects. Apply by hand or machine to remove light oxidation and create a long lasting, high gloss finish.
    CLEANER/WAX
    Item Number: M0664 64 oz. (1893 ml)
    POLYMER SEALANT
    Item Number: M2016 16 oz. (473 ml)
    Polymer Sealant is a unique blends of polymers, silicones and imported waxes that creates a brilliant high gloss finish that outlasts all other waxes. Safe and effective on all paint finishes, including clear coats.
    POLYMER SEALANT
    Item Number: M2064 64 oz. (1893 ml)
    SYNTHETIC SEALANT
    Item Number: M2116 16 oz. (473ml)
    Meguiar's® NEW M2116 Professional Synthetic Sealant
    Synthetic polymer formulation provides technologically advanced paint care and protection.
    Produces a noticeable deeper, darker, more reflective paint finish
    Synthetic polymers deliver extreme protection
    Elminates fine scratches and swirls, creating a flawless finish
    Glides on easy, with a smooth, resistance-free wipe-off
    SYNTHETIC SEALANT
    Item Number: M2164 64 oz.
    Synthetic Polymer formulation provides technologically advanced paint care and protection. Produces a noticeably deeper, darker, more reflective paint finish. Synthetic polymers bond to paint, delivering extreme protection. Eliminates fine scratches and swirls, creating a flawless finish. Very easy wipe-on and wipe-off .
    HI-TECH YELLOW WAX
    Item Number: M2601 1 gal. (3726 ml)
    Hi-Tech Yellow Wax is a premium yellow Carnauba wax blended with silicones, polymers and other waxes. Adds richness and depth of color. Provides ultimate high gloss protection to any previously cleaned and polished paint finish. Available in liquid or paste.
    HI-TECH YELLOW WAX
    Item Number: M2616 16 oz. (473 ml)
    QUICK DETAILER
    Item Number: M6601 1 gal. (3726 ml)
    Quick Detailer is a one-step cleaner/wax specially formulated for high-production reconditioning. Quickly and safely removes oxidation and blemishes. Restores deep gloss and provides a durable wax finish.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Three Rings AvantJunkie's Avatar
    Jul 17 2009
    Too much shit.
    Longview, WA
    ^^lol!
    OP, if you're referring to the 105/205 combo, I highly recommend it. Both are super easy to work with and achieve great results, even if you have little experience detailing. All you need is PC or similar, and a free day.
    **Brett**
    2002 A4 Avant 1.8TQM Brilliant Black/Platinum with some stuff.
    My car and I have a lot in common--we're both kind of old and slow, but still manage to look pretty fucking cool.
    Aug 17 2009
    Pittsburgh
    I actually just used the meguiars clay bar kit yesterday on my b6. it worked better than most clay bar kits i've used. i'd try that before going with a true rubbing compound as a clay bar will clean up a LOT of scratches and swirls, without the extra work of buffing, polishing, and waxing afterwards.
    Oct 09 2008
    Miguires Ultimate compund
    The Awesome™
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    I recently used Megs Ultimate Compound and a PC on my sister's white 4runner and I got results like the BMW above. Her paint was in similar condition too. I was very, very pleased with the results. From what I have read, Ultimate Compound is basically an OTC version of Megs 105. Ultimate Compound was a great choice and is available at any auto store.
