Results 1 to 19 of 19
    Oct 11 2009
    A4 S2.0T 2008
    What's the difference btw 2003/04/05 for A4?
    I usually try to stay away from 1st production year of new models, so I was wondering if there are any notable upgrades/improvements between 2003-05 for both 1.8/3.0? Any particular year that I should stay away from? Thx
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    02 has the lowest sport suspension
    -Andrew
    Frankenturbo/GIAC
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    There are no problems with 02 models. All years are the same. It all depends how the previous owner was treating the car. 04 are nicer cause u can get 6sp tranny and painted lowers.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by BASARAB View Post
    Hmm, that depends on what the OP is looking for, there a definite differences to consider.
    Off the top of my head.......
    1.No leatherette in the later years(Mine 02 leatherette has a crack on the left boltster)
    2.No 6-speed with 1.8t on the early years
    3.No USP
    4.There was a change in the turbo inlet pipe design(no effect on performance)
    5.There are some VAG-COM tweaks that can be done with 02-03 than can't be done with later years
    6. No heated rear seats on 03-04
    That's all I can think of right now, but you are right about reliability of the 02-06 models, there really is no difference.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Senior Member Two Rings SLeal's Avatar
    May 27 2010
    Vancouver
    Quote Originally Posted by manhertm View Post
    3.No USP
    My 04 has heated rears
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    the 04 i'm working on has heated rears!
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Three Rings A4.Rob's Avatar
    Sep 02 2009
    Toronto, Ontario
    Quote Originally Posted by android3000 View Post
    i know a lot of peope say that but is there proof of this some place?
    2003 Audi A4 1.8TQM
    Jun 26 2008
    00' Noggy Stg2
    in 01, and it might of spilled out into 02 there were 2 codes for sport, one being almost 20mm lower then the other. My buddies 01.5 b5 a4 has the extra lower sport suspension.
    It might be what is going on here and they might of stopped offering it.
    Oct 11 2009
    A4 S2.0T 2008
    I have to choose between an A4 1.8 2003 w/40k miles or a 2005 w/65k miles both at the same price, both in good condition...so, should I go for the 2003?
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Get the 03, if you want potentially less maintenance . Once you get pass 70k, the more expensive maintenance kicks in(timing belt etc). If you don't drive a lot and care about resale, I guess the 05 might be the better choice , but in a year or two , 2 years of difference won't matter much in terms of resale.
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by rockblock View Post
    I would suggest an 05. U gotta consider not only mileage, but age of car. All that hoses,tunes,valves get older too. But again, have u checked maintenance records,amount of owners e.t.c. ? Are those cars manual or automatic? And dont buy FWD, or u will hate yourself later lol
    Oct 11 2009
    A4 S2.0T 2008
    That's kind of my dilema...if a car has been sitting for 2 years without putting any mileage (especially in colder regions), I would assume there has to be some sort of impact on, say timing belt (expansion,contraction due to temp changes)...and yes I'm only looking for quattro as I live in Toronto
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Is one of them a USP?
    Mar 01 2010
    Farmington Hills,Mi
    Yeah, it these hours need to be driven, my friend has an 02 and drives it like a maniac, and it never breaks down. While I got an 04 and the car has been sitting in a storage before it was bought bought. I already have replaced bunch of hoses and valves under the hood.
    Veteran Member Four Rings jsantiago17's Avatar
    Aug 07 2008
    2004 A4 Quattro3.0L UltraSport
    Westchester, NY
    Quote Originally Posted by black99.5a4 View Post
    I have an 04 USP and it looks like I would have heated rears, but there isn't a switch to actually turn them on.
    |Milltek Exhaust|Unitronic Flashed|JHM Short Shifter|Koni Sports|Eibach Pros|RS4 Rear Sway|Euro RS4 Steering Wheel|RS4 Race Pedals|Miro 111's|S4 Mirrors|
    |B6 S4 Calipers|JHM 2 Piece Lightweight Rotors|Akebono Euro Ceramic Brake Pads|Evoms CAI|Hoen Xenon Match Foglights
    http://www.youtube.com/watch?v=xccmzudcY8o
    http://www.youtube.com/watch?v=BZOJIV1y0EQ
    Established Member Two Rings ruphianh's Avatar
    Mar 26 2010
    Palo Alto, CA
    The tunes get older? ??explain this
    Oct 11 2009
    A4 S2.0T 2008
    Quote Originally Posted by spector View Post
    no usp...I did see a 2002 w/55k miles and sport package though at the same price
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    if the switches are there, theyre located below the rear ash tray.
    Aug 07 2008
    Westchester, NY
    Quote Originally Posted by heywier427 View Post
    Yeah....I know that's where they'd be, but unfortunately they are not. On the side of the seats, it has the symbols for heated seats, but no such luck with the switches to turn them on!
