Results 1 to 19 of 19
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    clutchmasters fx850. which discs do i have??
    so.. the good ole RS4 pp only stood up to 15k stage 3 miles and 100+ passes and launches at the drag strip. so i am in dire need of 2 things. a new, stronger, better clutch setup for 1. and 2, the money to purchase a new, stronger, better clutch setup. so.. very related, these things are. and.. as lucky of a guy as i am, i have an amazing woman as a wife. she loves my car and me modding it which is super cool. and her dad just happens to be a representative of a number of parts manufacturers. (not why i married her you assholes )
    any how, he was able to hook me up with a new clutch setup. i asked him for the most aggressive setup, a double ceramic. but.. beggers cant be choosers, so id be happy with what he can get me. so here are some pics, and i cant find any other pics. can anyone tell me if this is organic/organic, organic/ceramic, or ceramic/ceramic. mind you, im only putting about 475wtq and 475whp on race gas to the ground. so i think either way, this clutch will do the job and more. and then if/when i go big turbo, i can always change out the discs for a more aggressive setup.
    here are the pics. thanks in advance dudes!!
    RS6 hybrids and corn
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    Hard to tell from the pics but it looks like ceramic/iron to me.... which is pretty damn aggressive :-)
    Registered User Three Rings Jason@Addict's Avatar
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    The CM's come as follows from MOST aggressive to LEAST aggressive:
    Dual Cerametallic w/ no sprung hub
    Dual Cerametallic w/ single sprung hub
    Half Cerametallic, Half Kevlar w/ no sprung hub
    Half Cerametallic, Half Kevlar w/ single sprung hub
    Dual Kevlar w/ no sprung hub
    Dual Kevlar w/ single sprung hub
    There are no variations in clamp rate. The Kevlars will slip better for daily driving, but won't last as long when beat on. ANY combination will hold the power. The metallics take longer to wear in, but when they do offer surprisingly good feel. I have sold and used every combination and really don't have any complaints about any of them. You obviously have the half and half with a sprung hub which is nice set-up! Score from the Dad-in law!
    Make sure you check the bolt length as they normally need to be shaved down slightly.
    Sep 28 2009
    ky
    Quote Originally Posted by Jason:addict View Post
    awesome!! so ill be happy with this as a daily driver AND the drag strip 4 times a year?? and you mean pp to flywheel bolts or flywheel to crankshaft bolts??
    thanks jason!
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    Quote Originally Posted by bigern45 View Post
    thanks jason!
    Yeah I think you'll love it though you have now moved the failure point to the axles and mounts. The crankshaft bolts will likely need to be shortened very slightly - no threads cut generally just the tapered portion at the very end of the bolt.
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    rich-
    who would have ever guessed we'd always seem to be in the same boat with our cars! I also just got an fx850 from jason lol, I think you will be happy with it ;)
    '00 Nogaro Blue S4
    Sep 28 2009
    ky
    what discs did you go with chris? im thinking with my power levels, as long as i break this thing in properly, it should hook like all get out. then i can really put those BF goodrich radials to use!!
    Veteran Member Three Rings davenew's Avatar
    Jan 20 2006
    VA
    That's what I had to do. It would be bad if they were too long.. because the bolts would torque and you would think they're good.. but they're really bottomed out in the hole.
    2000 Widebody S4, 41k miles, ASP GT2860R "-5" kit. EPL dyno tune: 575whp 93+meth, 600whp E85, 650whp E85+meth (2.36 sec FATS) (sold)
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Quote Originally Posted by davenew View Post
    I did damage one of my crank because of the too long bolts !
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Veteran Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Quote Originally Posted by NogaroWonda00 View Post
    Ordered mine from him as well. Should be at my door on Tuesday! Lookin good rich.
    Sep 28 2009
    ky
    yeah mike, im pumped.. should have my metal slave from USP shortly, cant wait to tear it apart!!!
    and thanks to everyone about the too long bolts. i woulda probably found out the hard way..
    Sep 28 2009
    ky
    so what is the measurement to look at for the bolts?? just take a few mm off the end of the bolt? or do i need to look at the old ones?? can i just install washers on the clutchside, or will that interfere with the clutch??
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    dial calipers. measure the bolt holes in the crank and add that to the thickness of the flywheel. that should be greater than the length of the bolts to assure you dont bottom them out.
    Jun 13 2008
    Rocky Mountains
    Rich I got the Kevlar one, it really is odd how streetable it is, and you may now realize that you may have had that rs4 slipping. At least that's what I thought after the first launch with it lol...
    '00 Nogaro Blue S4
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Jason, which would you recommend for a car that is daily driven? Will a cerametallic last longer than the kevlar one?
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    Quote Originally Posted by Evilevo View Post
    The metallics will last longer, but the kevlars will engage far easier for a DD application. I actually prefer the feel of the metallics once they break-in, but I also drive twins often.
    Sep 28 2009
    ky
    van halen baby.. best of both worlds!! lol.. when i go super nasty with this project car, ill go stupid nasty clutch, i think my setup once broken in properly will suffice.. i think my power level (470whp) wont even make my setup sweat.. i hope itll last longer than 15000 miles..
    Sep 28 2009
    ky
    got the slave today, looks great USP!! thanks!! ill try to post some picks up later of the slave, and im getting into the teardown tonight, hopefully ill have some pics of my SB and RS4 pp...
    Sep 28 2009
    ky
    so, got the transmission out tonight, and this is what i found..
    no broken fingers like i expected, although the SAC is adjusted to all the way worn. perhaps i was too violent?? and it just fell out of adjustment that way?? and so it caused my clutch to behave oddly?? you can see how the springs are completely unloaded..
    and here was the clutch side of the pp, again, no major heat cracks, but there is a lot of ridges and streaks!!! when i was taking this thing off, tons, and i mean TONS!! of metal and clutch shavings fell on me. i expected some dust, but not this....
    and then the flywheel, which looks similar to the pp..
    so, i guess it was a combination of the pp not clamping hard enough, or the SAC coming all the way unajdusted somehow, that caused the clutch to overheat, as you can see where the pucks where binded to the sprung disc. you can tell the SB stage 4 is no lightweight, but i guess the heat and inability to perform on the part of the pressure plate caused chunks of it to just disintegrate, that was well as the flywheel. the clutch wore out this bad?? and i never smelled it at all, except on passes where i seemed to hook great and the clutch not slip.. or maybe just the everyday driving of the car and then all of a sudden the drag strip, two complete differences as far as changes of pace occured, and it was just too much for it.. oh well, ill get some more pics of the install and such with the flywheel and clutch/usp slave cylinder tomorrow..
