Results 1 to 6 of 6
    Established Member Two Rings ClashCity's Avatar
    Dec 16 2007
    B6 Avant, XC90 Volvo
    Rancho Cucamonga
    Jack points for tire rotation (AVANT)
    I would like to rotate the tires on my Avant, but noticed their is nowhere to place the floor jack to lift-up one side of the car. What is the safest way to do this. I belive the rotation is back to front? Where would I place the floor jack? I do have two jack stands to help with the process.
    Senior Member Three Rings Barker29's Avatar
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    there are points to use the jack theyre right in front of the rear wheel and behind the front wheel. Its the pinch point of the body. There should be a spot where the plastic missing or is thinner becasue its meant for the jack in your car...http://www.audizine.com/forum/showth...of-jack-points
    And be careful of the rotation if you have quattro because that changes everything. I have directional tires so im not sure exactly how non directional are rotated on a quattro
    Jun 30 2008
    Erie, Pennsylvania
    Tire rotation is generally in an X formation, aka "X-rotating". That is swapping Left Front tire with the Right Rear tire, and likewise. The only time you cannot do this is if your tires are directional - they will usually have an arrow on the sidewall indicating the correct rotation. It should be simple to see in the tread pattern as well. In this case you can only rotate back to front on each side.
    you can lift any car up right below the B piller to do the whole side just be carful and use some wood between the jack and the car.
    The best way to do it is with one jack and one jack stand. Jack the back up and put it on a jack stand then jack the front up. Rotate your tires and repeat on the other side.
    450whp 17psi @ 6400rpm on pump
    I am an a$$hole!
    SpecClutch.com | 034Efi.com | BoostFactory.net | QEDPower.com
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by RecklessTuning View Post
    You can also just jack up on the front on the normal jacking point seam and if you have a tall jack it'll get both wheels of the ground. I always change my tires using the high jack method, sames a lot of time.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Senior Member Three Rings JeffM03's Avatar
    Dec 30 2009
    Waterbury, VT
    Quote Originally Posted by lookaught View Post
    I use that method too. Works like a charm.
    Denim Blue 3.0L V6 Quattro Tiptronic || I jury-rig everything.
