Results 1 to 2 of 2
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    License Plate Bulbs - Screw Size?
    Hey Everyone,
    This might be a long shot, but I was wondering if anyone knew the "approximate" size for the license plate bulb screws? The actual screws that hold in the small covers above the license plate the house the bulbs.
    One of mine is sagging a bit because the screw was not able to be screwed in all the way (the plastic broke) so I'm looking for a replacement that I can screw in there so everything is nice and tight. The problem with the loose covers is sometimes the bulbs become loose from where they need to sit...so they don't light up.
    Anyway, if anyone has any ideas on the size of the screws I need, I would GREATLY appreciate it!!
    Thanks in advance!
    --Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Three Rings Lou-quattro's Avatar
    Dec 29 2009
    B5 S4
    Peoria, AZ
    Go to ace hardware with the screws and show them and theyll find you exact replacements in a sec. Did this myself when i was swapping to LED bulbs.
