Results 1 to 7 of 7
    Veteran Member Three Rings jaimeson's Avatar
    Jun 22 2009
    Bikes, Viper, Duramax
    Am I reading this right?
    IINM, cam chain tensioners are between 4 and 6 hundred dollars but searching around today on Pure MS, I found this > http://www.purems.com/products/product.php/II=1589
    I was always told it's recommended to replace then when you have heads rebuilt but I personally wasn't gonna spend that much unless they were bad and had to be replaced. Anyways, just wanted to put this out there.
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Yes, replace no matter what the cost. this is a part that goes out often and can cost much more down the line.
    These are what you need. Normally about $1100 anywhere else for the pair. this is a good deal.
    http://www.purems.com/products/product.php/II=2738
    http://www.purems.com/products/product.php/II=2739
    Red Car - Under the knife
    Silver Car - ALIVE
    Jun 22 2009
    I understand the importance of changing them but there should be noticeable slack in the chain if needed replaced correct?
    Mar 21 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    Log blocks 91 and 92 IIRC. That will tell you if they are dying. On a WOT pull you should see the cam adjustment go from 0 to 22 at around 4000 rpm IIRC. Both should be doing the same thing. If one or both aren't holding 22 then it's broken and you should replace it.
    If you compress those cam adjusters to remove the cams they are likely to break. That's what happened to mine :-/
    Veteran Member Three Rings DaveS4's Avatar
    Apr 12 2009
    Nova Scotia, Canada
    The compression tool was my problem, I broke two of them :(
    2001.5 VAST Stage3 **** Silver * 6 Speed
    2001.5 Completely Stock * Imola * Automagical
    May 16 2008
    South Texas
    Quote Originally Posted by jaimeson View Post
    That tensioner is for the 1.8.. The 2.7 tensioners are about $300-450 each. If you building a high dollar motor, this is something I'd put on the parts list.
    Jun 22 2009
    Like I said, "am i reading this right" ?
    My bust, thanks for the pointer on checking it through VAG
