Results 121 to 152 of 152
Threaded View
    Jul 12 2010
    Q5 3.0T
    DIY LED Reverse Light
    Edit:
    Originally Posted by awhk82 View Post
    I have disabled the reverse light bulb error check with VAGCOM. Now running LED bulbs without any issue.
    Here are the steps:
    Module 46 Central Convenience > Security Access 16 > 16017
    Adaption 10 > Channel 181 > Convert your decimal number to binary (for example my default number in decimal is 65535, converted to binary = 1111111111111111), then change bit 10 and 11 from 1 to 0 (my new binary value becomes 1111001111111111, which is 62463 in decimal) > Enter the new binary value > Test > Save
    T10 style LED w/ resistor would work
    Open trunk lining to access rear lights
    Just 2 clips holding it in place
    Access to internals
    Just one screw holding it in place; remove it
    Unattach 2 wires to remove circuity board
    Internal Board
    Pull to remove old bulb, replace with new LED
    Comparison with old bulb
    New LED reverse light (sorry guys, I tinted my reverse and turn signal lamp area, else it could have been brighter)
    2010 A4 quattro, Tiptronic, Ibis White
