Results 1 to 11 of 11
    Sep 07 2010
    centreville va
    Oil in the 4th coilpack... why??
    I have a 2007 Audi a4 that I just got 10k miles ago I went in for a oil change last month and they told me about the recall on the coilpacks so they replaced them for me. About 3k miles later my oil light came on and I added oil, about 1500 miles later it came on again so I added a full qt or oil. that oil lasted about 1700 miles. I went online and read something about the 2007 models burning oil and that basically there was nothing that could be done. so I left it at that. Today I went out to clean my car and also clean under the hood I noticed where oil was pooling up around a screw. after looking into it further I pulled out the 4th (closest to the battery) coilpack and it had been sitting in a pocket of oil. I cleaned it off and got as much oil out on the shaft as possible the oil was black so it wasn’t new oil. I took out the 3rd one and noticed a little oil in there also not nearly as much though. number 1 and 2 were oil free. what is the reason there is oil in the coil pack? will it hurt anything?
    Senior Member Three Rings HPW's Avatar
    Sep 30 2008
    2013 A3 TDI
    Pasadena, Ca
    PCV... search it up, there are plenty of threads about it. i'm surprised that coil didn't go bad since there was oil in it already, but oil and coilpacks generally don't mix well. you need to get the PCV fixed.
    ____________________________________________
    2013 A3 TDI S-line Titanium
    RIP: 2007 A4 Avant 2.0T S-line Titanium APR AWE Hotchkis H-Sport - Totaled by iPhone wielding inattentive driver
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Quote Originally Posted by HPW View Post
    Not necessarily PCV... Ive had oil in the 4th coilpack before also, VALVE COVER GASKET.
    Sep 07 2010
    centreville va
    Quote Originally Posted by B72.0T View Post
    I say Valve cover gasket also. im about to make a 11 hour car trip each way before getting it looked at though so hopefully the CP will last since they are new... does anyone know how much 2 CP will cost?
    Apr 13 2010
    Union Beach NJ
    Yup... I just replaced both. It happened right after I got my car flashed. Oil was all over the place under the hood.
    Sep 07 2010
    centreville va
    sorry that happend. how much did the new CP set you back?
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    If your car is CPO, bring it in to the dealer and have them take care of it. Otherwise they run for 20-30 bucks a piece.
    Sep 02 2008
    Boonies VA
    Was this gasket covered under CPO? The reason I ask is that I am noticing a little oil around one of my coilpacks (2nd in from front of the car) but I have the BSH PCV fix. It does not look like much oil, and if I get time I plan to take out the coilpacks this weekend to check them all.
    Problem is that I will have to remove the BSH PCV, and reinstall my busted old one (still have it) for the dealer to even bother looking. I am sure then that they will see the PCV is needing repair, replace that, send me on my way only for me to have to go back again to tell them it is still leaking oil. At 100 miles round trip to the dealership I want to minimize any trips there if possible!!
    White Wagon
    Dec 18 2009
    Pennsylvania
    I dont have a CPO, but it was covered under my regular 50,000 mile warranty.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by naiku View Post
    My valve cover was replaced under warranty a couple of weeks ago.
    Senior Member Three Rings tdavit's Avatar
    Aug 27 2005
    CT, FL
    i had the same oil in the coilpack problem and it ended up being a small tear in the valve cover gasket a real PIA. thankfully i was under warranty at the time.
